When I performed RAS-2SF excited state calculations on the DDMX molecule (an example in the Q-chem program), the following problem occurred: After I fixed the same self-consistent field data, the output results completely changed just by changing the number of roots, and they were all different from the data in the ras-2sf reference.
Here are my output files.I only show the first three excited states. The data presented at such low energy levels are completely different.
Can you check my input file and give me some advice for solving this problem?
RAS(4,4)-2SF-CI low-lying states of DDMX tetraradical
C 0.000000 0.000000 1.092150
C -1.222482 0.000000 0.303960
C -2.390248 0.000000 1.015958
H -2.344570 0.000000 2.095067
H -3.363161 0.000000 0.537932
C -1.215393 0.000000 -1.155471
H -2.150471 0.000000 -1.702536
C 0.000000 0.000000 -1.769131
C 1.215393 0.000000 -1.155471
H 2.150471 0.000000 -1.702536
C 1.222482 0.000000 0.303960
C 2.390248 0.000000 1.015958
H 2.344570 0.000000 2.095067
H 3.363161 0.000000 0.537932
jobtype sp
method rasci
basis 6-31g*
max_scf_cycles 200
scf_convergence 8
!scf_algorithm dm
unrestricted false ! RASCI only works with unrestricted orbitals
scf_guess read
sym_ignore true
!RASCI
RAS_ROOTS 9 ! Compute 9 states
RAS_ELEC 4 ! Active electrons (RAS2)
RAS_ACT 4 ! Active orbitals (RAS2)
RAS_OCC 25 ! Doubly occ orbitals (RAS1)
RAS_DO_HOLE true ! Compute hole contributions (RAS1 -> RAS2)
RAS_DO_PART true ! Compute part contributions (RAS2 -> RAS3)
RAS_SPIN_MULT 0 ! Compute any spin multiplicity
RAS_NATORB true ! Compute natural orbital occupancies
! RAS_ACT_ORB [26,27,28,29] ! Pick active orbitals
! RAS_NATORB_STATE 2 ! Save natural orbitals of state 2 in file 53.0
! RAS_GUESS_CS 1 ! Force (at least) 1 close shell guess
SCF converges when RMS gradient is below 1.0e-08
Cycle Energy RMS Gradient
1 -306.1969607828 5.54e-09 Convergence criterion met
The disked orbital energies are calculated using alpha and beta Focks
SCF time: CPU 3.67s wall 0.00s
<S^2> = 6.000000000
SCF energy in the final basis set = -306.1969607828
Total energy in the final basis set = -306.1969607828
Q-Chem warning in module /public/home/huangxk/qchem/libsym/oriorb.F, line 198:
OriOrb: Failure to resolve orbital degeneracies.
RAS-CI total energy for state 1: -306.196637466801
Excitation energy (eV) = 0.000000000000
Multiplicity: Triplet
Dipole Moment: -0.0000 X 0.0000 Y -0.4275 Z
Amplitudes :
| HOLE | ALPHA | BETA | PART | AMPLITUDE
| | 1100 | 0011 | | 3.3470690850813E-01
| | 1010 | 1001 | | 3.0932847034804E-01
| | 1010 | 0101 | | 2.9756762997754E-01
| | 1001 | 1010 | | -3.0932847034802E-01
| | 1001 | 0110 | | -3.8717863878017E-01
| | 0110 | 1001 | | 3.8717863878021E-01
| | 0110 | 0101 | | -2.2937908465369E-01
| | 0101 | 1010 | | -2.9756762997752E-01
| | 0101 | 0110 | | 2.2937908465367E-01
| | 0011 | 1100 | | -3.3470690850819E-01
*** Contributions RASCI wfn Active: 99.76
Hole: 0.11
Part: 0.14
NATURAL OCCUPATION NUMBERS (higher than 1.0E-05)
1 2 3 4 5 6
1 2.0000000 2.0000000 2.0000000 2.0000000 2.0000000 2.0000000
7 8 9 10 11 12
13 14 15 16 17 18
1 2.0000000 2.0000000 2.0000000 1.9999998 1.9999996 1.9999994
19 20 21 22 23 24
1 1.9999968 1.9999955 1.9999952 1.9999942 1.9999631 1.9996040
25 26 27 28 29 30
1 1.9995604 1.1393807 1.0001290 0.9998572 0.8605271 0.0005405
31 32 33 34 35
1 0.0003054 0.0000714 0.0000426 0.0000123 0.0000119
RAS-CI total energy for state 2: -306.183766634779
Excitation energy (eV) = 0.350233158637
Dipole Moment: -0.0000 X 0.0000 Y -0.4050 Z
Trans. Moment: -0.0000 X 0.0000 Y 0.0122 Z
Strength : 0.000001
Amplitudes :
| | 1100 | 0011 | | -4.9827250669190E-01
| | 1010 | 1001 | | 1.1094076749640E-01
| | 1010 | 0101 | | -1.7521930725883E-01
| | 1001 | 1010 | | -1.1094076749636E-01
| | 1001 | 0110 | | -4.1776182635766E-01
| | 0110 | 1001 | | 4.1776182635772E-01
| | 0101 | 1010 | | 1.7521930725885E-01
| | 0011 | 1100 | | 4.9827250669183E-01
*** Contributions RASCI wfn Active: 94.47
Hole: 2.96
Part: 2.57
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
1 1.9999999 1.9999996 1.9999994 1.9999985 1.9999971 1.9999949
19 20 21 22 23 24
1 1.9999926 1.9999762 1.9999695 1.9999154 1.9997436 1.9921757
25 26 27 28 29 30
1 1.9846820 1.0189454 1.0019739 1.0002726 0.9810318 0.0149786
31 32 33 34 35 36
1 0.0059072 0.0001834 0.0001335 0.0000609 0.0000223 0.0000134
RAS-CI total energy for state 3: -306.166970992664
Excitation energy (eV) = 0.807265833686
Multiplicity: Singlet
Dipole Moment: 0.0000 X -0.0000 Y -0.7068 Z
Trans. Moment: 0.0000 X 0.0000 Y 0.0000 Z
Strength : 0.000000
Amplitudes :
| | 1010 | 1010 | | 3.8839138300971E-01
| | 1010 | 0110 | | 3.4020306004333E-01
| | 1001 | 1001 | | -2.6023743925514E-01
| | 1001 | 0101 | | -3.0959273915830E-01
| | 0110 | 1010 | | 3.4020306004592E-01
| | 0110 | 0110 | | -2.4513662548918E-01
| | 0101 | 1001 | | -3.0959273916094E-01
| | 0101 | 0101 | | 1.9460771412498E-01
| 25 | 1011 | 0110 | | -1.3399427392223E-01
| 25 | 0110 | 1011 | | -1.3399427392274E-01
| | 0100 | 1001 | 30 | 1.1200120894898E-01
| | 1001 | 0100 | 30 | 1.1200120894861E-01
*** Contributions RASCI wfn Active: 73.99
Hole: 14.91
Part: 11.10
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
1 2.0000000 1.9999998 1.9999996 1.9999974 1.9999900 1.9999820
19 20 21 22 23 24
1 1.9999561 1.9999219 1.9999149 1.9998159 1.9969552 1.9852515
25 26 27 28 29 30
1 1.9743459 1.2094035 1.1588053 0.8491658 0.7915534 0.0225778
31 32 33 34 35 36
1 0.0103035 0.0014597 0.0002305 0.0001433 0.0000805 0.0000534
37 38 39 40
1 0.0000255 0.0000157 0.0000133 0.0000128
jobtype sp
method rasci
basis 6-31g*
max_scf_cycles 200
scf_convergence 8
!scf_algorithm dm
scf_guess read
sym_ignore true
!RASCI
RAS_ROOTS 10 ! Compute 9 states
1 -306.1969607827 1.22e-06 Normal BFGS step
2 -306.1969607827 6.79e-08 Normal BFGS step
3 -306.1969607827 4.19e-08 Normal BFGS step
4 -306.1969607827 7.73e-09 Convergence criterion met
SCF time: CPU 7.43s wall 1.00s
<S^2> = 6.000000000
SCF energy in the final basis set = -306.1969607827
Total energy in the final basis set = -306.1969607827
RAS-CI total energy for state 1: -306.196637466808
Dipole Moment: 0.0000 X 0.0000 Y -0.4275 Z
Amplitudes :
| | 1100 | 0011 | | 3.3470687858438E-01
| | 1010 | 1001 | | 3.0932877827623E-01
| | 1010 | 0101 | | 2.9756757814028E-01
| | 1001 | 1010 | | -3.0932877827621E-01
| | 1001 | 0110 | | -3.8717852414608E-01
| | 0110 | 1001 | | 3.8717852414613E-01
| | 0110 | 0101 | | -2.2937900443102E-01
| | 0101 | 1010 | | -2.9756757814030E-01
| | 0101 | 0110 | | 2.2937900443101E-01
| | 0011 | 1100 | | -3.3470687858438E-01
Hole: 0.11
Part: 0.14
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
19 20 21 22 23 24
25 26 27 28 29 30
1 1.9995604 1.1393814 1.0001290 0.9998572 0.8605265 0.0005405
31 32 33 34 35
RAS-CI total energy for state 2: -306.193360763828
Excitation energy (eV) = 0.089163624595
Dipole Moment: -0.0000 X 0.0000 Y 0.1248 Z
Trans. Moment: 0.0000 X 0.0135 Y -0.0000 Z
Strength : 0.000000
Amplitudes :
| | 1100 | 1010 | | 6.4733284925364E-01
| | 1100 | 0110 | | -1.7445488462412E-01
| | 1010 | 1100 | | -6.4732513315631E-01
| | 0110 | 1100 | | 1.7448266974484E-01
| 25 | 1011 | 1100 | | -1.0139032975449E-01
| 25 | 1100 | 1011 | | 1.0138636064193E-01
*** Contributions RASCI wfn Active: 92.05
Hole: 5.07
Part: 2.88
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
1 2.0000000 2.0000000 1.9999999 1.9999997 1.9999992 1.9999984
19 20 21 22 23 24
1 1.9999979 1.9999764 1.9999758 1.9999485 1.9997480 1.9980053
25 26 27 28 29 30
1 1.9876997 1.9389797 0.9999403 0.9980288 0.0728014 0.0025846
31 32 33 34 35 36
1 0.0013129 0.0005440 0.0002359 0.0001460 0.0000256 0.0000181
37
1 0.0000128
RAS-CI total energy for state 3: -306.190584369951
Excitation energy (eV) = 0.164713145829
Dipole Moment: -0.0000 X -0.0000 Y 0.1266 Z
Trans. Moment: -0.0000 X 0.0000 Y 0.0000 Z
Strength : 0.000000
Amplitudes :
| | 1100 | 1010 | | 6.4773439452054E-01
| | 1100 | 0110 | | -1.7263435762566E-01
| | 1010 | 1100 | | 6.4772689052646E-01
| | 0110 | 1100 | | -1.7267377351272E-01
| 25 | 1011 | 1100 | | 1.0136523426430E-01
| 25 | 1100 | 1011 | | 1.0136477506426E-01
*** Contributions RASCI wfn Active: 92.03
Hole: 5.10
Part: 2.87
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
1 2.0000000 2.0000000 1.9999999 1.9999997 1.9999975 1.9999972
19 20 21 22 23 24
1 1.9999964 1.9999904 1.9999715 1.9999604 1.9997453 1.9980609
25 26 27 28 29 30
1 1.9870187 1.9388173 0.9999035 0.9979904 0.0735297 0.0026447
31 32 33 34 35 36
1 0.0013223 0.0005535 0.0003081 0.0001229 0.0000310 0.0000165
References:
