Dear Qchem Community,
I am trying to do a RASCI calculation starting from previously converged CASSCF orbitals because I wanted slightly better orbitals than the HF one. However in doing so the energy of the orbitals is completely wrong and I don’t know why. Here you have the input of casscf:
coord
GUI 2
UNRESTRICTED FALSE
MAX_SCF_CYCLES 100
scf_algorithm DIIS
EXCHANGE hf
CAS_METHOD 2
CAS_M_S 0
CAS_N_ELEC 8
CAS_N_ORB 8
CAS_N_ROOTS 8
MEM_TOTAL 8000
MEM_STATIC 2000
CAS_SAVE_NAT_ORBS TRUE
MAX_CASSCF_CYCLES 400
CAS_USE_RI TRUE
AUX_BASIS RIJK-def2-svp
BASIS def2-svp
And here the RASCI input:
coord
GUI 2
SCF_GUESS READ
SKIP_SCFMAN true
scf_algorithm DIIS
EXCHANGE hf
CORRELATION rasci
UNRESTRICTED False
BASIS def2-svp
!RAS-CI
RAS_ROOTS 10
RAS_ELEC 2
RAS_ACT 2
RAS_OCC 170 !SOMO is 171
N_FROZEN_CORE 155
N_FROZEN_VIRTUAL 485 !462
RAS_DO_HOLE false
RAS_DO_PART false
SET_ITER 200
RAS_SPIN_MULT 0
RAS_PRINT 2
!MEMORY
MEM_TOTAL 8000
MEM_STATIC 2000
MAX_CIS_CYCLES 200
I don’t know if it is relevant, but I noticed that if I read the fchk files and I noticed that in the mo energies section the file print the occupation number insted:
Alpha Orbital Energies R N= 869
2.00000000E+00 2.00000000E+00 2.00000000E+00 2.00000000E+00 2.00000000E+00
2.00000000E+00 2.00000000E+00 1.95860603E+00 1.95208081E+00 1.94303420E+00
1.00010871E+00 1.00000015E+00 5.34494109E-02 5.16369993E-02 4.10836883E-02
3.60318087E-14 2.73087508E-14 2.56748322E-14 2.26716960E-14 2.13774709E-14
2.01754683E-14 1.90715559E-14 1.90083567E-14 1.78080141E-14 1.76899983E-14
1.65075577E-14 1.52138273E-14 1.51445208E-14 1.49731500E-14 1.43664098E-14
1.43362863E-14 1.42160373E-14 1.40762473E-14 1.38276447E-14 1.38018957E-14
1.29914629E-14 1.29539434E-14 1.27447568E-14 1.23413523E-14 1.22142709E-14
1.11967049E-14 1.09875103E-14 1.08851698E-14 1.06295839E-14 9.69886080E-15
9.68039258E-15 9.42683461E-15 9.11515037E-15 8.93719177E-15 8.72030290E-15
8.52217256E-15 8.28488145E-15 8.27397326E-15 7.99600221E-15 7.84066997E-15
7.80690806E-15 7.75779988E-15 7.73774024E-15 7.29750129E-15 7.19279556E-15
7.15939664E-15 7.12596775E-15 6.85950079E-15 6.79254110E-15 6.69310866E-15
I am pretty sure the input are loaded and saved in the right way because if I do the same using DFT orbitals I do not encounter similar error
Thank you for your help
