Resolution of identity for CDFT?
cloning this to a separate thread so as not to clutter previous discussion.
Having to run larger, more expensive constrained DFT jobs with hybrid functionals so I started to explore the resolution of identity-based approximations. However, I find with the following input (RI_J and occ-RI-K) that it segfaults immediately before the first SCF cycle. Using Qchem 6.3.
  C      6.30855022     -4.93788338      3.88865279
  H      6.46844030     -5.83477413      3.28091071
  C      5.01765030     -4.35035744      4.19205135
  H      4.04802354     -4.72207231      3.84570655
  C      5.23841495     -3.22386205      5.02651884
  H      4.47447698     -2.55909283      5.44169462
  C      6.66721159     -3.10150946      5.22621529
  H      7.15976745     -2.33556271      5.83473897
  C      7.31655349     -4.20719489      4.58681439
  H      8.38968765     -4.41966656      4.59195632
  C      6.21501810     -1.01803699      2.56079378
  H      6.09904537     -0.12748159      3.18572776
  C      7.47643922     -1.62182529      2.21664122
  H      8.46168129     -1.27259229      2.54082808
  C      7.20721274     -2.73851668      1.37478405
  H      7.94488276     -3.41511989      0.93265470
  C      5.78075005     -2.82732645      1.20681162
  H      5.27058208     -3.57749332      0.59529050
  C      5.15516226     -1.69391917      1.85096660
  C      3.74477713     -1.34129407      1.83063937
  C      2.79744585     -2.10924529      1.10156345
  H      3.10807348     -3.02219605      0.58703002
  C      1.47285868     -1.69375406      0.97701026
  H      0.77759409     -2.27246231      0.35960808
  C      1.05307597     -0.50071272      1.58786675
  C      1.94333084      0.24494950      2.36842866
  H      1.63232837      1.17047784      2.85630207
  C      3.26858932     -0.17875360      2.48969492
  H      3.95611436      0.43480123      3.07808950
 Co      6.25310142     -2.97668890      3.20704943
  N     -0.32023883     -0.01937991      1.29546237
  C     -0.56952759      1.42091634      1.63016136
  H      0.20840818      2.02914160      1.15160308
  H     -1.55666329      1.68346606      1.22473574
  H     -0.56324389      1.55048325      2.72087926
  C     -1.37583337     -0.89912011      1.91359579
  H     -1.21877777     -1.93280239      1.57691648
  H     -1.28362197     -0.83601280      3.00726190
  H     -2.36068006     -0.53706103      1.58448065
  H     -0.41746428     -0.06422855      0.25424860
  C      2.74081181      0.23358296     -1.33464848
  C      3.07781445      1.33939183     -0.52471591
  C      3.77785252     -0.57596110     -1.85603517
  H      2.27171878      1.96727642     -0.13667488
  H      3.54385475     -1.43198863     -2.49568935
  C      4.41385497      1.62501708     -0.23428591
  C      5.11313185     -0.29445065     -1.55455647
  H      4.66306364      2.49129425      0.38751464
  H      5.90839827     -0.93004235     -1.95696942
  C      5.43472279      0.80285844     -0.73853255
  H      6.48090493      1.02669988     -0.50553360
  C      1.31075073     -0.06995661     -1.57864311
  O      0.41861174      0.57454350     -0.99120839
  C      0.93672357     -1.17041692     -2.54385239
  H      1.37713004     -2.13610755     -2.23949946
  H     -0.15882613     -1.26433396     -2.58213330
  H      1.32148929     -0.94112848     -3.55429865
   METHOD       TPSSh
   MEM_TOTAL    400000
   JOBTYPE      opt
   BASIS        def2-tzvpp
   AUX_BASIS	RIJK-def2-tzvpp
   SCF_CONVERGENCE 8
   XC_GRID      2	SG-2
   RI_J 	TRUE
   OCC_RI_K 	TRUE
   RI_K_GRAD 	TRUE
   MAX_SCF_CYCLES 200
   GEOM_OPT_MAX_CYCLES 100
   SOLVENT_METHOD   smd
   DFT_D        D4
   CDFT         true
   CDFT_THRESH  8
   NO_REORIENT  true
   POINT_GROUP_SYMMETRY false
   INTEGRAL_SYMMETRY    false
   MOLDEN_FORMAT   TRUE
$smx
solvent THF
$opt
   CONSTRAINT
   stre  31  53  2.47538
   ENDCONSTRAINT
$cdft
   -1.0
   1 1 40
   1.0
   1 1 40 s
/global/homes/s/foo/qchem: line 122: 2090781 Segmentation fault      ${QCPROG_S} ${inp} ${scr}
Error in Q-Chem run part 1
When the memory is lowered to 4K (in case it’s allocated per thread), a different segfault results:
corrupted double-linked list
/global/homes/s/foo/qchem: line 122: 2357577 Aborted                 ${QCPROG_S} ${inp} ${scr}
Error in the Q-Chem run
Last time I tried this with def2-SVP on 6.2.1, it barely squeaks out the first SCF cycle before a similar segfault.
With RI_J set to false (so only occ-RI-K and the corresponding gradient) the job runs but very slowly, 8 hours for 2 converged SCF cycles. With def2-SVP, it’s about an hour per converged SCF cycle. The analytical gradients didn’t seem to be available in any of these cases for CDFT.
Just running the hybrid functional CDFT without the RI approximations, the opt job runs and completes normally with def2-TZVPP and takes about 20 node-hours for 25 geometry steps. I could afford to use it for a few single point calculations but not for the full dataset.
Possibly all of this is a CDFT issue so I am trying a test job without.
Note that CDFT is implemented only in Q-Chem’s old SCF code so some of the modern accoutrements may not be available. You can tell because the title block
  Bang C. Huynh
for the new SCF code is not printed in CDFT jobs.
for sure - if that’s the case, so be it…
Oddly enough, with CDFT removed there is still a crash.
METHOD       TPSSh
MEM_TOTAL    400000
JOBTYPE      opt
BASIS        def2-tzvpp
SCF_CONVERGENCE 8
XC_GRID      2	SG-2
RI_J 	TRUE
OCC_RI_K 	TRUE
RI_K_GRAD 	TRUE
MAX_SCF_CYCLES 200
SOLVENT_METHOD   smd
DFT_D        D4
NO_REORIENT  true
MOLDEN_FORMAT   TRUE
$smx
solvent THF
$opt
CONSTRAINT
stre  31  53  2.47538
ENDCONSTRAINT
  Bang C. Huynh
 Exchange:     0.1000 Hartree-Fock + 0.9000 TPSS
 Correlation:  1.0000 TPSS
 Dispersion:   Grimme D4
 The following algorithms are not available for rij_occrik, because:
  Algorithm libdf::reuse2e3c@0x361f8f28 for rij_occrik is not capable because of input use_libqints = false
  Algorithm libdf::recompute2e3c@0x361f8fa0 for rij_occrik is not capable because of input use_libqints = false
gen_scfman_exception: hamiltonian: algorithm selector failure
 Q-Chem fatal error occurred in module libgscf/gen_scfman/gen_scfman_main.C, line 244:
 Error in gen_scfman
In this case, USE_LIBQINTS = TRUE had to be set to get it to run, which I wasn’t able to find documentation for.
Based on some experimentation, this appears to be an incompatibility between RI and the solvation model. For SOLVENT_METHOD = PCM you get a message to that effect, but that doesn’t get triggered here (although it should). I will submit a ticket.
Got it, thanks for reporting that. I was able to get RI-J + occ-RI-K + SMD to run normally with USE_LIBQINTS = TRUE and CDFT off. It converged to something resembling the desired CDFT state, so this may be usable, but I don’t know what downstream implications the use of LIBQINTS would have (just because it ran without crashing doesn’t mean what I did is legal).
With USE_LIBQINTS = TRUE and CDFT on again, it crashes with:
free(): invalid size
/global/homes/s/foo/qchem: line 122: 638175 Aborted                 ${QCPROG_S} ${inp} ${scr}
Which settings did you see the SOLVENT_METHOD = PCM warning for?
Use SOLVENT_METHOD = PCM with RI-SCF keywords, gives message. (I think I put the message there some time ago.)
