Restraints in optimisation
Hi All,
I want to optimise a structure with some restraints. I would like to prevent atoms from moving in the ‘x’ cartesian direction.
Would the input be something like:
$opt
FIXED
1 X
2 X
etc…
ENDFIXED
thank you!
That is how you would do a restraint in X.
So that will keep the X coordinates fixed?
Yes. It will also force the optimizer to use Cartesian coordinates, which will likely take a lot of steps.
I have input the restraints in the way specified, but when visualised they have moved so that the Cartesian axis are pointing in a different direction to the initial input, do you know why?
Did you specify the following in your input?
SYMMETRY false
maybe also NO_REORIENT = TRUE, which forces Q-Chem to use the user’s lab-fixed frame, whereas by default the molecule is rotated into Standard Nuclear Orientation ( = principle axes of nuclear charge).
