SCF not convergence, I can’t optimize my structure in solution environment which was optimized in vacuum. This is my input(structure was optimized in vacuum environment):
Cl 1.5746745308 0.0070770309 -0.0289671039
N 4.5855687067 -0.0029326501 -0.0235189175
N -4.8998317514 0.0113217088 0.0425701874
C -0.0715926499 1.9929355693 -2.2153032733
C -0.0502589085 -2.8763924230 -0.6038172432
C -0.0357830409 0.9010986116 2.8043819804
H -0.0356494869 1.9542602131 2.5669540335
C -0.0334259356 3.8608401344 -0.0149781104
C -0.0468406709 -1.9636597204 -3.3435003841
C -0.0125031709 -1.9344174212 3.3442993869
H -0.0126789508 4.5479408731 0.8191404478
O 3.0139196483 4.2598740515 0.6637116342
O -3.0904947923 4.3198298082 0.7017125927
O 2.9368580327 1.7785842865 2.6154288771
O -2.9742944222 1.6264928742 2.1357901998
C 2.5516649517 3.5719879636 -0.2048778967
C 2.5425793626 -1.9679714406 -3.0248154209
C 2.5763872778 -1.6417986363 3.1679517358
C -2.6232616662 3.5337189884 -0.0711555802
C -2.6340963859 -1.8470423751 -3.0018547875
C -2.6063925596 -1.7016618587 3.1242263492
C 1.1023753939 2.5133338622 -1.7004552415
C 1.1132959990 -2.7066360132 -1.3314780477
C 1.1338835098 0.1880752170 2.9933953887
C -1.2199428683 2.4035179119 -1.5650465178
C -1.2064978272 -2.5340340592 -1.2784241990
C -1.1888587416 0.1414361781 2.8519866595
C 2.5005885461 2.1072352725 -2.0146712893
C 2.5157451653 -2.7625974729 -0.8359479215
C 2.5319561845 0.6558672673 2.7912179288
C -2.6014540066 1.9082314966 -1.7419300387
C -2.5813947592 -2.4299895185 -0.7461914391
C -2.5701236581 0.5496589706 2.5222879218
C 1.1265314576 3.3980377124 -0.6255695916
C 1.1220200612 -2.2448501241 -2.6450437528
C 1.1522137566 -1.1837319852 3.2303562011
C -1.2129272587 3.3286258828 -0.5149990842
C -1.2173817199 -2.1173777351 -2.6146809949
C -1.1896114847 -1.2280031298 3.1418754365
N 3.2951771853 2.7230324886 -1.0473311561
N 3.2989389087 -2.2532822799 -1.8706612702
N 3.3222010812 -0.4914372224 2.8418854304
N -3.3859420552 2.5881640108 -0.8161059594
N -3.3808342611 -1.9965234720 -1.7969833410
N -3.3644353391 -0.5794155494 2.6788595120
C 4.7079753946 2.4580214121 -0.8838078553
C 4.7101514635 -1.9670432257 -1.7371412750
C 4.7349572794 -0.4984507476 2.5294935984
C -4.8265630666 2.4723237457 -0.7602753387
C -4.8215169007 -1.8985921263 -1.7085611126
C -4.8066350422 -0.5532016167 2.5675385816
H 5.1863073140 3.3824312563 -0.5596037215
H 5.1789612305 -2.1369457527 -2.7064129946
H 5.2156692411 -1.2430091132 3.1640787435
H 5.1148781153 2.1986431188 -1.8578290472
H 5.1333553927 -2.6806350121 -1.0348336852
H 5.1397848076 0.4755220338 2.7922433410
H -5.1912275341 2.2843193856 -1.7682367363
H -5.1786438940 -2.6864919852 -1.0485458519
H -5.1590274052 0.4104883532 2.9308558027
C 5.0410585673 1.4247814719 0.1999334097
C 5.0304631132 -0.5110932421 -1.3783546608
C 5.0592735942 -0.9130124491 1.0891517493
C -5.3572016666 1.4479852462 0.2458008558
C -5.3524007976 -0.5217223371 -1.3076101535
C -5.3586253814 -0.8860800370 1.1801780843
H 6.1248665380 1.3941284249 0.3211275347
H 6.1119823960 -0.3765120917 -1.4234530983
H 6.1419493672 -0.9982175193 0.9885586210
H 4.5898247344 1.7508170071 1.1321207636
H 4.5624042434 0.1313927917 -2.1178977087
H 4.6070501767 -1.8830406770 0.9068966400
H -5.0322757074 1.7338451502 1.2391366362
H -5.0219548036 0.2021458234 -2.0425241909
H -5.0493998561 -1.8901505651 0.9164010893
H 3.5154942827 -0.0039320425 -0.0109829682
H -3.8773417564 0.0106798947 0.0503383885
H -0.0790023161 1.2646825220 -3.0124552610
H -0.0414069819 -3.1772060661 0.4330344809
H -0.0382812449 -1.6037058780 -4.3625602879
H 0.0026390978 -2.9988830092 3.5309681461
O 2.9927966817 -1.5704096330 -4.0641338477
O 3.0355785792 -2.7374952609 3.3384079062
O -3.1159208519 -1.5920620781 -4.0678186721
O -3.0799662051 -2.7562787839 3.4351240165
O 2.9020569676 1.4005196594 -2.9058648916
O 2.9280911234 -3.1532881349 0.2285590061
O -3.0116681247 1.0488459912 -2.4934441029
O -2.9774097563 -2.6216234211 0.3846357228
H -5.2224057945 3.4355794858 -0.4363581949
H -5.2236110430 -2.0890034101 -2.7041764548
H -5.1989414770 -1.3234107663 3.2325504269
H -6.4453567788 1.4288260296 0.2022179264
H -6.4407507888 -0.5466155495 -1.2726488446
H -6.4459342007 -0.8252759489 1.1967054517
JOBTYPE OPT
METHOD B3LYP
BASIS def2-TZVPP
SOLVENT_METHOD SMD
DFT_D D3
SCF_ALGORITHM l_bfgs
MEM_TOTAL 40000
MEM_STATIC 10000
SCF_MAX_CYCLES 200
GEOM_OPT_MAX_CYCLES 400
$smx
solvent water
and my output:
performed using Roothaan-Hall, L-BFGS
Cycle Energy DIIS error
1 -3438.6055624981 1.16e-02 Roothaan Step
L-BFGS subspace size: 20
Cycle Energy Error
1 -3421.1203574123 6.65e-03 LineSearch Step
gen_scfman_exception: I think this should be impossible
Q-Chem fatal error occurred in module libgscf/gen_scfman/gen_scfman_main.C, line 223:
Error in gen_scfman
