I am trying to perform a TDDFT calculation for a dye - water system. Previous attempts for TDDFT of dye was successful. Because of that I have been using a similar input for the current calculation. Only difference is surrounding water box is modeled using electrostatic embedding (JANUS). I have attached the input and output file of this. I tried setting different MEM_TOTAL values assuming a memory issue while also completely removing the MEM_TOTAL flag. Still the calculation crashes at the very beginning with “segmentation fault: core dumped” error. I appreciate any thoughts as to validity of the input and what I could try to address the error.
output:
 6376      H       7.8110000000    35.9350000000    25.2140000000
 Nuclear Repulsion Energy =           0.00000000 hartrees
 There are    10739 alpha and    10739 beta electrons
 Total QAlloc Memory Limit   2000 MB
 Mega-Array Size       188 MB
 MEM_STATIC part       192 MB
   **** Step 1: MM energy contributions ****
 AMBER99 force field loaded.
 Time req'd to get MM system information: 693.8 s (CPU) 694.2 s (wall)
          Please provide the input.
          My input exceeds the body limit for messages. What is the recommended way to share the input file?
          Then please find a smaller example that fails in the same way.  This is always the recommended procedure when reporting bugs:  minimal example.
FYI, if all you want to do are single point TDDFT calculations with point-charge embedding, it’s probably easier to use the $external_charges section rather than the Janus QM/MM, which is under-developed.  TDDFT with external charges works for very large MM regions (have done it myself), but it’s for single-point calculations only.
          I tried to do the same calculation with removing majority water molecules. Now the calculation proceeds however I am getting a different error.
 Time req'd to get MM system information: 0.0 s (CPU) 0.0 s (wall)
Unknown angle bending parameter for 21-42-30
 Q-Chem fatal error occurred in module forceman/angle_params_AMBER.C, line 230:
 Undefined angle parameter.
   PDB: so3sq_water-traj1-extract.pdb.1
   Janus YingYang embedding. MM: AMBER99 (water+ions). QM: wB97x-D/6-31+G* (SO3SQ).
   20 excited states. Assumed MM interactions same for excited and ground states.
   Gaussian-blurred MM charges, width: 1.5 Ã….
    C   25.221000   19.485000   17.045000  0
    O   26.375000   19.525000   17.519000  0
    C   24.792000   19.399000   15.677000  0
    C   23.566000   18.692000   16.074000  0
    O   22.802000   18.078000   15.449000  0
    C   24.103000   18.618000   17.410000  0
    C   24.694000   17.635000   22.442000  0
    H   24.874000   17.623000   23.513000  0
    C   25.145000   18.746000   21.775000  0
    H   25.511000   19.564000   22.389000  0
    C   24.923000   18.750000   20.369000  0
    H   25.148000   19.619000   19.752000  0
    N   24.397000   17.639000   19.712000  0
    C   23.850000   16.606000   20.396000  0
    C   24.018000   16.526000   21.782000  0
    H   23.599000   15.666000   22.295000  0
    C   23.735000   17.691000   18.504000  0
    C   22.760000   16.734000   18.423000  0
    C   22.828000   15.982000   19.587000  0
    C   21.801000   14.906000   20.019000  0
    H   20.758000   15.243000   20.023000  0
    H   22.063000   14.494000   21.000000  0
    H   21.824000   14.094000   19.283000  0
    C   21.523000   17.193000   18.099000  0
    C   24.867000   17.971000   10.472000  0
    H   24.756000   17.414000    9.546000  0
    C   23.805000   17.892000   11.446000  0
    H   22.838000   17.613000   11.037000  0
    C   23.841000   18.561000   12.672000  0
    H   22.918000   18.789000   13.203000  0
    N   25.085000   19.047000   13.100000  0
    C   26.179000   18.893000   12.241000  0
    C   26.104000   18.527000   10.887000  0
    H   26.928000   18.767000   10.221000  0
    C   25.526000   19.481000   14.402000  0
    C   26.869000   19.779000   14.169000  0
    C   27.218000   19.442000   12.919000  0
    C   28.510000   19.938000   12.180000  0
    H   28.416000   20.152000   11.109000  0
    H   29.288000   19.172000   12.282000  0
    H   28.876000   20.866000   12.633000  0
    C   21.082000   18.543000   18.417000  0
    H   21.758000   19.167000   18.994000  0
    C   19.789000   18.999000   18.209000  0
    H   19.550000   20.029000   18.456000  0
    C   18.834000   18.167000   17.649000  0
    C   19.230000   16.839000   17.288000  0
    H   18.572000   16.071000   16.892000  0
    C   20.537000   16.392000   17.536000  0
    H   20.791000   15.374000   17.256000  0
    O   17.555000   18.490000   17.473000  0
    C   17.170000   19.838000   17.494000  0
    H   17.018000   20.214000   18.513000  0
    H   17.966000   20.362000   16.950000  0
    C   15.914000   20.116000   16.715000  0
    H   15.566000   21.132000   16.936000  0
    H   15.122000   19.457000   17.088000  0
    C   16.132000   19.830000   15.198000  0
    H   16.936000   20.497000   14.867000  0
    H   16.480000   18.800000   15.063000  0
    C   14.819000   19.948000   14.409000  0
    H   14.444000   20.979000   14.436000  0
    H   14.124000   19.220000   14.847000  0
    S   15.031000   19.386000   12.687000  0
    O   13.833000   19.936000   11.992000  0
    O   14.982000   17.947000   12.814000  0
    O   16.314000   19.941000   12.232000  0
    C   27.637000   20.719000   15.050000  0
    C   26.974000   21.795000   15.668000  0
    H   25.976000   22.068000   15.337000  0
    C   27.804000   22.706000   16.476000  0
    H   27.298000   23.539000   16.955000  0
    C   29.192000   22.363000   16.684000  0
    C   29.784000   21.187000   16.160000  0
    H   30.818000   20.904000   16.335000  0
    C   28.931000   20.316000   15.340000  0
    H   29.306000   19.430000   14.836000  0
    O   29.989000   23.160000   17.487000  0
    C   29.421000   24.310000   18.216000  0
    H   28.644000   24.034000   18.941000  0
    H   28.987000   24.979000   17.463000  0
    C   30.569000   24.915000   18.902000  0
    H   30.963000   24.095000   19.513000  0
    H   31.258000   25.215000   18.105000  0
    C   30.202000   26.124000   19.783000  0
    H   29.430000   25.929000   20.536000  0
    H   29.743000   26.947000   19.225000  0
    C   31.379000   26.730000   20.606000  0
    H   31.757000   25.987000   21.319000  0
    H   32.093000   27.111000   19.865000  0
    S   30.843000   28.221000   21.523000  0
    O   29.648000   27.778000   22.269000  0
    O   32.015000   28.637000   22.324000  0
    O   30.629000   29.174000   20.441000  0
    Na   0.266000   37.718000    4.366000  2004
    Na  37.413000   34.022000   20.981000  2004
    Na   6.051000   17.981000   29.361000  2004
    Na   3.264000   28.929000    8.808000  2004
    Na  36.702000   15.856000    2.857000  2004
    Na  25.861000    4.470000    9.358000  2004
    Na  46.038000   26.963000   27.611000  2004
    Cl  34.634000   21.974000   19.209000  2012
    Cl  22.968000   32.969000    5.942000  2012
    Cl  14.182000    1.803000    3.000000  2012
    Cl  37.232000   19.132000    7.483000  2012
    Cl  41.258000   26.765000   25.884000  2012
    O   23.239000    6.039000   14.345000  2001
    H   23.404000    6.884000   13.927000  2002
    H   22.327000    5.840000   14.132000  2002
    O   43.896000   32.519000   26.392000  2001
    H   43.065000   32.268000   25.990000  2002
    H   43.927000   32.022000   27.209000  2002
    O    5.716000   30.882000   33.006000  2001
    H    5.180000   31.606000   33.329000  2002
    H    6.618000   31.176000   33.134000  2002
   JOBTYPE             SP
   METHOD	       wB97x-D
   BASIS               6-31+G*
   QM_MM_INTERFACE     janus
   FORCE_FIELD         amber99
   GAUSSIAN_BLUR       true
   GAUSS_BLUR_WIDTH    15000
   MODEL_SYSTEM_CHARGE -2
   MODEL_SYSTEM_MULT   1
   CIS_N_ROOTS         20
   CIS_SINGLETS        true
   CIS_TRIPLETS        false
   RPA	               true
   MAXSCF              5000
   MEM_TOTAL           16000
$qm_atoms
1:94
I will also try to apply $external_charges approach for the MM region. The segmentation fault most probably resulted due to the large solvent box size I used (over 6000 atoms).
          It means that Q-Chem’s version of that force field parameter file doesn’t contain the bond-angle parameter that you want, which you would need to add.  If you’re just looking to add charges, use $external_charges.  If you’re really looking to do QM/MM, I suggest you look into one of the MM codes that can interface with Q-Chem.
          Thanks @jherbert for your valuable advice. I will move in to using $external_charges for this purpose.
