Simulating Vibronic and Resonance Raman Spectroscopy Using the VIBRONIC module of Q-Chem
Understanding the vibrational fine structure of electronic absorption and emission (vibronic) and vibrational resonance Raman spectroscopy plays an important role in characterizing molecular and electronic structure of molecules. In principle one needs the information of vibrational states on top of different electronic states to determine the corresponding spectroscopy signals.
Q-Chem provides a module VIBRONIC implemented by Xunkun Huang, Huili Ma and Wanzhen Liang [1-3] to simulate vibrationally resolved one-photon absorption (OPA) and one-photon emission (OPE) as well as resonance Raman spectroscopy (RRS). The key quantity to determine OPA, OPE and RRS signals is the polarizability tensor, which is usually in the form of sum-over-states (SOS). Evaluating SOS expressions could make the simulation costly. In the VIBRONIC module, the SOS expression is transformed into the time domain and the polarizability tensor is calculated through Fourier transform of the Green’s function (propagator) in the time domain. Currently the VIBRONIC module is available in TDHF, CIS and TDDFT calculations.
Since for these spectroscopies (OPA, OPE and RRS), two electronic states (the ground state g and the excited state e) are involved, the signal simulation usually consists of two steps (one step for each electronic state) except in the VG model. Available theoretical models at different levels of approximation include:
  1. FC1 (available for OPA, OPE and RRS simulation). The Franck-Condon (FC) approximation is employed. In this model both ground and excited state geometries are required, but on the ground state vibrational frequencies are necessary. The excited state vibrational frequencies are assumed the same as the ground state vibrational frequencies and the Duschinsky rotation effect is neglected.
  2. FC2 (available for OPA, OPE and RRS simulation). The Franck-Condon approximation is employed. Optimized geometries and vibrational frequencies are required both for the ground and excited states. Duschinsky rotation is included.
  3. FCHT (available for OPA, OPE and RRS simulation). Both the FC and Hertzberg-Teller (HT) terms in the transition dipole moment Taylor expansion are considered. Optimized geometries and vibrational frequencies are required both for the ground and excited states. Duschinsky rotation is included.
  4. VG (available for OPA and RRS simulation). The vertical gradient (VG) approximation is employed. Only ground state optimized geometry and vibrational frequencies are required and so the simulation can be finished in one step. The excited state vibrational frequencies are assumed the same as the ground state vibrational frequencies and the Duschinsky rotation effect is neglected. The displacement vector between the ground and excited state vibrational normal modes are approximately calculated from the excited state energy gradients (available in excited state force calculations). HT terms are also neglected.
The following are examples of vibronic spectroscopy and RRS simulations. Please make sure both steps of calculations should access the same scratch directory, as the vibronic parameters saved from the previous step should be available for the later step. In order to do so, one can either run a two-step job using the “@@@” delimiter, or run two separated calculations with the same predefined scratch directory name. For example, running the following commands:
qchem  input_file_for_state_1  output_file_for_state_1  your_scratch_directory_name
qchem  input_file_for_state_2  output_file_for_state_2  your_scratch_directory_name
The vibronic spectra simulation must run after the vibronic parameters are saved (see the examples below). In all simulations the $rem variable SYM_IGNORE must be set to TRUE in order to prevent the molecular geometry being transformed to the standard orientation. Q-Chem provides two $rem variables and one input section to control vibronic spectra simulation. For details please refer to the manual.
Example 1. Simulating the OPA signals of formaldehyde with TDDFT and the FC1 model.
Q-Chem Input for step 1: excited state (S1) geometry optimization (comments are put after the “!” sign and should be removed in case qchem does not run properly)
 O                  0.003000000    0.00000000    0.68241638
 C                  0.020000000    0.00000000    -0.57598362
 H                   -0.030000000    0.92664718    -1.11098362
 H                  0.004000000  -0.92664718   -1.11098362
  jobtype opt
  method b3lyp
  basis def2-TZVP
  cis_state_deriv 1    ! excited state no. 1
  cis_singlets true
  cis_triplets false
  cis_n_roots 10
  sym_ignore true    ! this must be set to TRUE
  save_vibronic_params true    ! save the vibronic parameter for later use
Q-Chem Input for step 2: ground state (S0) geometry optimization and frequency and OPA simulation (comments are put after the “!” sign and should be removed in case qchem does not run properly)
 O                  0.00000000    0.00000000    0.68241638
 C                  0.00000000    0.00000000   -0.57598362
 H                   -0.00000000    0.92664718   -1.11098362
 H                  0.00000000   -0.92664718    -1.11098362
  jobtype opt
  method b3lyp
  basis def2-TZVP
  sym_ignore true
  jobtype freq
  method b3lyp
  basis def2-TZVP
  sym_ignore true
  vibronic_spectra 1    ! simulating OPA
$vibronic    ! the input section to control vibronic spectra simulation
  model 1    ! using the FC model
  freq_range 20000. 60000. 10.    ! simulation frequency range parameters in cm-1.
  time_range 1.0000000 40000    ! time step size in a. u. and no. of steps.
  damping 40.00000            ! damping factor in cm-1.
Note: in order to break the symmetry, the starting geometry in step 1 is slightly different from that in step 2. In addition, excited state geometry optimization could be subtle. One should make sure the target excited state does not change its character (e. g., the order of all calculated excited states has not changed) during the geometry optimization process.
The resulted OPA signals are saved in a file named “abs_spectra.dat” and can be plotted as
vib-1
The scratch files used in the OPA signal calculation can be found in a directory called “your_output_file_name.files” under the same directory as where the output file is generated.
Example 2. Simulating the OPE signals of formaldehyde with TDDFT and the FC2 model.
Q-Chem Input for step 1: excited state (D1) geometry optimization and frequency calculation (comments are put after the “!” sign and should be removed in case qchem does not run properly)
 C         1.4840482200        0.0000338155        0.0000000000
 C         0.7160497031        0.0000524901       -1.2119311870
 C        -0.7159596058    0.0000542629       -1.2126930961
 C        -1.4043236629    0.0000543088        0.0000000000
 C        -0.7159596058    0.0000542629        1.2126930961
 C         0.7160497031        0.0000524901        1.2119311870
 C         2.8748450131        0.0000120580        0.0000000000
 H         1.2370230923        0.0000896598       -2.1693859212
 H        -1.2717579173    0.0000412967       -2.1497435961
 H        -1.2717579173    0.0000412967        2.1497435961
 H         1.2370230923        0.0000896598        2.1693859212
 H         3.4346492051        0.0000003003       -0.9330758768
 H         3.4346492051        0.0000003003        0.9330758768
 F        -2.7508602624    0.0000394216        0.0000000000
  jobtype opt
  method b3lyp
  basis def2-SVP
  cis_state_deriv 1
  cis_singlets true
  cis_triplets false
  cis_n_roots 10
  sym_ignore true
  jobtype freq
  method b3lyp
  basis def2-SVP
  cis_state_deriv 1
  cis_singlets true
  cis_triplets false
  cis_n_roots 10
  sym_ignore true
Q-Chem Input for step 2: ground state (D0) geometry optimization and frequency calculation and OPE simulation (comments are put after the “!” sign and should be removed in case qchem does not run properly)
 C         1.4566183503        0.0129101640        0.0000000000
 C         0.7101644786        0.0081907583       -1.2185833193
 C        -0.6759989496       -0.0007979055       -1.2214548662
 C        -1.3520058015       -0.0052290244    0.0000000000
 C        -0.6759989496       -0.0007979055    1.2214548662
 C         0.7101644786        0.0081907583        1.2185833193
 C         2.8635151754        0.0218512897        0.0000000000
 H         1.2491028005        0.0118050196       -2.1666316459
 H        -1.2458865325       -0.0044564748       -2.1504521674
 H        -1.2458865325       -0.0044564748    2.1504521674
 H         1.2491028005        0.0118050196        2.1666316459
 H         3.4244334505        0.0256959046       -0.9338584025
 H         3.4244334505        0.0256959046        0.9338584025
 F        -2.7015919823       -0.0141481171    0.0000000000
  jobtype opt
  method b3lyp
  basis def2-SVP
  sym_ignore true
  jobtype freq
  method b3lyp
  basis def2-SVP
  sym_ignore true
  vibronic_spectra 2    ! simulating OPE
$vibronic
  temperature 0.    ! simulation temperature in K.
  freq_range 1. 40000. 10.
  time_range 1. 40000
  damping 20.
Note: One should confirm that the excited state geometry really is at a local minimum by the calculated vibrational frequencies.
The resulted OPE signals are saved in a file named “emiss_spectra.dat” and can be plotted as
vib-2
Example 3. Simulating the RRS signals of phenoxyl with TDDFT and the FCHT model.
Q-Chem Input for step 1: excited state (D3) geometry optimization and frequency calculation (comments are put after the “!” sign and should be removed in case qchem does not run properly)
 C         0.0000000000        1.2502862746       -1.0797670264
 C         0.0000000000        0.0002405852       -1.8221303158
 C         0.0000000000       -1.2495301785       -1.0796765524
 C         0.0000000000       -1.2430453219    0.2902274202
 C         0.0000000000       -0.0000629947    1.0386563677
 C         0.0000000000        1.2431472440        0.2901098645
 H         0.0000000000        2.1927860816       -1.6322129361
 H         0.0000000000       -0.0006440427       -2.9122962915
 H         0.0000000000       -2.1925083031       -1.6316088409
 H         0.0000000000       -2.1692045915    0.8680624075
 H         0.0000000000        2.1689368505        0.8682996003
 O         0.0000000000       -0.0004016035    2.3373913028
  jobtype opt
  method b3lyp
  basis def2-SVP
cis_state_deriv 3    ! excited state no. 3
  cis_singlets true
  cis_triplets false
  cis_n_roots 10
  sym_ignore true
  jobtype freq
  method b3lyp
  basis def2-SVP
  cis_state_deriv 3
  cis_singlets true
  cis_triplets false
  cis_n_roots 10
  sym_ignore true
Q-Chem Input for step 2: ground state (D0) geometry optimization and frequency calculation and RRS simulation (comments are put after the “!” sign and should be removed in case qchem does not run properly)
 C         0.0000000000        1.2267763413       -1.0873977233
 C         0.0000000000        0.0003129951       -1.7857718635
 C         0.0000000000       -1.2259217607       -1.0872681918
 C         0.0000000000       -1.2399944954    0.2921692642
 C         0.0000000000       -0.0001222804    1.0534497246
 C         0.0000000000        1.2400986319        0.2919975911
 H         0.0000000000        2.1644176592       -1.6487443117
 H         0.0000000000       -0.0006702414       -2.8784475224
 H         0.0000000000       -2.1641202680       -1.6480392688
 H         0.0000000000       -2.1702849650    0.8642269804
 H         0.0000000000        2.1700059139        0.8643911139
 O         0.0000000000       -0.0004975303    2.3044892072
  jobtype opt
  method b3lyp
  basis def2-SVP
  sym_ignore true
  jobtype freq
  method b3lyp
  basis def2-SVP
  sym_ignore true
  vibronic_spectra 3    ! simulating RRS
$vibronic
  model 2    ! using the FCHT model
  temperature 0.
  freq_range 1. 4000. 1.
  time_range 1. 40000
  damping 100.
  epsilon 25.    ! line broadening factor for RRS, in cm-1.
The resulted RRS signals are saved in a file named “rrs_spectra.dat” and can be plotted as
vib-3
Example 4. Simulating the RRS signals of phenoxyl with TDDFT and the VG model.
Q-Chem Input: ground state (D0) geometry optimization and frequency calculation and excited state force calculation (comments are put after the “!” sign and should be removed in case qchem does not run properly)
  jobtype opt
  method b3lyp
  basis def2-SVP
  sym_ignore true
  jobtype force        ! excited state force calculation
  method b3lyp
  basis def2-SVP
  cis_state_deriv 3
  cis_singlets true
  cis_triplets false
  cis_n_roots 10
  sym_ignore true
  jobtype freq        ! ground state frequency calculation
  method b3lyp
  basis def2-SVP
  sym_ignore true
$vibronic
  model 3    ! using the VG model
  temperature 0.
  time_range 1. 40000
  damping 100.
  epsilon 25.
vib-4
Reference:
[1] Wanzhen Liang et al., J. Phys. Chem. B, 110, 9908 (2006).
[2] Huili Ma, Jie Liu and Wanzhen Liang, J. Chem. Theory Comput., 8, 4474 (2012).
[3] Wanzhen Liang, Huili Ma, Hang Zang and Chuanxiang Ye, Int. J. Quantum Chem., 115, 550 (2015).
FCFs can also be computed by a post-processing code ezFCF, which provides more flexibility in terms of underlying electronic structure method:
The software is described in this paper:
https://onlinelibrary.wiley.com/doi/epdf/10.1002/wcms.1546
Greetings,
Do you have any recommandations of how to chose the dampind and epsilon factors in order to get high resolution spectrum for example?
Thanks
I’m contacting the author of this vibronic module for an answer.
The following is the reply from Prof. WanZhen Liang:
“These two quantities are closely related to the spectral resolution and are determined by the excited-state lifetime which is dependent on the molecule itself and its environment. You may take the same value for the two quantities in your calculation. Usually the smaller the higher resolution. However, if you input a smaller value, you have to calculate the propagation matrix for longer time because we adopt the time-dependent approach to calculate the RRS spectra. We firstly calculate the spectral cross sections in time-domain then made the Fourier transformation to them back to the frequency domain.
If the experimental spectra or molecular excited-state lifetime are available,you may take the values based on the experimental data.”
How do you determine the frequency range suppose you dont have access to experimental spectra
You should choose the parameters to obtain the resolution that you want. Use some preliminary TDDFT single-point calculations to figure out the relevant excitation energies for the bright electronic states.
Hi Prof. Herbert,
I am specifically interested in S0-S1 absorption band, in which my vertical excitation energy is 2.52 eV , ZPE corrected adiabatic energy is 2.079 eV. How can I figure out from this values?
Thank you for the help.
I think you need to consult the papers of Wanzhen Liang, cited above and in the Q-Chem manual.
Hi yzhang,
I tried running your exact example input for formaldehyde to test the workflow, but even with your exact input, it finishes without generating the abs_spectra.dat file.
would you send me how i can manage to get them and what do you think cause
I am running this on an HPC cluster. I suspect that when the calculation transitions between Step 1 and Step 2, the cluster’s environment is either completely erasing the temporary node scratch space or assigning a different random path, meaning Step 2 cannot find the saved parameters from Step 1.
Since the exact example fails to output the .dat file on my cluster, could you share how you structurally run these two steps? Do you put them into a single file with @@@ delimiters, or do you have to explicitly define a specific QCSCRATCH environment directory in your cluster submission script to force the steps to share the same folder?
The description of the output may be out of date for recent versions of Q-Chem. (The original post is 5 years old…). Please see the relevant section of the manual:
https://manual.q-chem.com/latest/subsec_vibronic.html
On a cluster, you may need to modify your batch script to pull the scratch files back from the compute nodes to your home directory upon completion. In SLURM, for example, this looks like:
cd $SLURM_SUBMIT_DIR
$QC/bin/qchem -nt <num_threads> -save inputfile outputfile scrname
cp -r $QCSCRATCH/scrname .
thank you so much it is so helpfull
Hello, when tried this calculation for simple molecule it was working well but changing to a bigger one is too complicated to get the file spectra.dat in the end there was no imaginary frequencies but it still not ending well kinda crushing while Getting Ground/Excited-state Information
Can you please be more clear and specific about what is the problem?
This was my input file for OPA calculation using method 1 FC and even for FCHT i checked the output file and the log file that i got but they were showing no negative frequencies which means that calculation are normal without anomalies but i didn’t get the spectra file in the end while there was no text in the output file which shows that the calculation are ending normally SO THIS my used input file and the molecule was so simple having H and C atoms do you think that changing the basis set can lead to good results or i should add some specific parameters
JOBTYPE freq
METHOD wB97X-D
BASIS def2-SVP
CIS_STATE_DERIV 1
CIS_SINGLETS true
CIS_TRIPLETS false
CIS_N_ROOTS 10
point_group_symmetry False
SAVE_VIBRONIC_PARAMS true ! enables saving information of S1 state
MEM_TOTAL = 500000
MEM_STATIC = 8000
JOBTYPE freq
METHOD wB97X-D
BASIS def2-SVP
VIBRONIC_SPECTRA 1 !enables vibronic_spectra and reads saved information
MEM_TOTAL = 500000
MEM_STATIC = 8000
$vibronic
model 1
time_range 1. 40000
damping 40.
so the vibronic_spectra.log that i got in the end of calculation is ending in this way
TimeDomain Info, DeltaT and PointCount : 52.9754 517
Get Ground/Excited-state Information
while the OUTPUT FILE is ending like this without giving any spectra file.dat
Vibrational Resolved Spectra Simulation
spectra saved in xxx_spectra.dat
log of calculation in vibronic_spectra.log
I think that this block of text at the end,
is out of date with regard to the file names. With the most recent version of Q-Chem (v. 6.4), what I get is a directory FILENAME.files (where FILENAME is the name of your Q-Chem output file), which seems to contain relevant information. This information is copied back to the working directory from the job’s scratch directory.
The first picture is the files that i got from the example shown in the manual and i got spectra.dat
but the picture 2 is what i got now for my compound and it is crushing in the end as i showed you in the log file how it was ending
where i didn’t get any results
i am using Q-chem 6.3 version i hope this will clarify my question
If the job crashes then you are probably not going to get abs_spectra.dat. You need to diagnose why it’s not running to completion. If it works with the test job in the manual, then perhaps your molecule or basis-set size is exceeding the capabilities of your hardware (e.g., need more memory or more it’s being cut off by a wall-time limit). Is the calculation in fact running to completion?
