SOC calculation on EOM-CCSD
I try to run spin orbit coupling on EOM-CCSD but i get error . I attached here my input file .
Please advise to resolve this problem.
Thank you
Here i attached my input
Cl -0.10937500 -0.12500000 0.00000000
METHOD eom-ccsd
BASIS 6-31G
CIS_N_ROOTS 4
CIS_CONVERGENCE 8
MAX_SCF_CYCLES 600
MAX_CIS_CYCLES 50
SCF_ALGORITHM diis
MEM_STATIC 500
MEM_TOTAL 8000
SYMMETRY false
CIS_SINGLETS true
CIS_TRIPLETS true
CALC_SOC 2
SET_ITER 300
what is the error? can you please paste part of the output?
Q-Chem 6.0.2 for Intel X86 EM64T Linux
Parts of Q-Chem use Armadillo 9.900.5 (Nocturnal Misbehaviour).
http://arma.sourceforge.net/
Q-Chem begins on Mon Mar 20 17:13:09 2023
Host:
0
 Scratch files written to /home/planck/software/Qchem/scr/qchem20108//
Dec722 |scratch|qcdevops|jenkins|workspace|build_RNUM 7806
Processing $rem in /home/planck/software/Qchem/config/preferences:
Processing $rem in /home/planck/.qchemrc:
Core orbitals will be frozen
Checking the input file for inconsistencies… …done.
User input:
METHOD eom-ccsd
BASIS 6-31G
CIS_N_ROOTS 4
CIS_CONVERGENCE 8
MAX_SCF_CYCLES 600
MAX_CIS_CYCLES 50
SCF_ALGORITHM diis
MEM_STATIC 500
MEM_TOTAL 8000
SYMMETRY false
CIS_SINGLETS true
CIS_TRIPLETS true
CALC_SOC 2
SET_ITER 300
1      Cl     -0.1093750000    -0.1250000000     0.0000000000
Nuclear Repulsion Energy = 0.00000000 hartrees
There are 9 alpha and 8 beta electrons
Requested basis set is 6-31G
There are 4 shells and 13 basis functions
Total memory of 8000 MB is distributed as follows:
MEM_STATIC is set to 500 MB
QALLOC/CCMAN JOB total memory use is 7500 MB
Warning: actual memory use might exceed 8000 MB
Total QAlloc Memory Limit 8000 MB
Mega-Array Size 489 MB
MEM_STATIC part 500 MB
A cutoff of 1.0D-14 yielded 10 shell pairs
There are 109 function pairs
Smallest overlap matrix eigenvalue = 1.68E-01
Scale SEOQF with 1.000000e+00/1.000000e+00/1.000000e+00
Nucleus-field energy = 0.0000000003 hartrees
SAD guess density has 17.000000 electrons
Bang C. Huynh
Hartree-Fock
using 10 threads for integral computing
A unrestricted SCF calculation will be
performed using DIIS
Cycle Energy DIIS error
1    -459.2437429005      2.64e-03
2    -459.4408606720      3.83e-03
3    -459.4421366515      2.27e-03
4    -459.4427244430      1.11e-03
5    -459.4429358661      1.12e-04
6    -459.4429393283      1.80e-05
7    -459.4429394146      2.96e-06
8    -459.4429394164      1.34e-06
9    -459.4429394167      4.92e-08
10 -459.4429394167 5.76e-09 Convergence criterion met
SCF time: CPU 3.50s wall 0.00s
<S^2> = 0.750551896
SCF energy in the final basis set = -459.4429394167
Total energy in the final basis set = -459.4429394167
MAX_CIS_SUBSPACE fits in available memory
Direct UCIS calculation will be performed
Using Frozen Core approximation: 5 lowest orbitals not used
CIS energy converged when residual is below 10e- 8
NRoots was altered as:4 -->5
1 0 5 0.073322 0.017651
2 0 5 0.016031 0.007014
3 0 5 0.001235 0.000552
4 5 0 0.000000 0.000000 Roots Converged
After that job kill. I dont understand why that happen?
I can verify this crash with the latest trunk. However, you are mixing CIS keywords with METHOD = EOM-CCSD. Are you following some example job in the manual? The calculation crashes following convergence of the CIS roots. If I change METHOD to HF, this job runs to completion and prints SOC info.
