Spherical or Cartesian
Are d and f and higher basis functions in Q-Chem 6.4 and 7 defaulted to Spherical or Cartesian? If spherical, how are they exported in a fchk file? My search has found mixed answers to the Spherical or Cartesian default question.
Thanks for any help.
The answer depends on the basis set. However, the behavior is controllable by setting PURECART. (See the manual; the most important cases are 1111 for all spherical or 2222 for all Cartesians.) You ought to be able to verify by counting basis functions and checking with the Q-Chem output, where the number of basis functions is printed. Use PRINT_GENERAL_BASIS = TRUE to verify what basis functions are included.
Thanks John. I’m using the def2-SVP basis. Is there somewhere in the Q-Chem manual that provides the information I need?
I’m not sure if the default pure/cart settings are in the manual although the REMs that I indicated are certainly described in the manual. You can run a job like this:
    O   -0.702196054  -0.056060256   0.009942262
    H   -1.022193224   0.846775782  -0.011488714
    H    0.257521062   0.042121496   0.005218999
method hf
basis  def2-svp
purecart 1111
print_general_basis true
method hf
basis def2-svp
purecart 2222
method hf
basis def2-svp
The first input uses spherical harmonics for all angular momentum classes, the second enforces all Cartesian, and the third requests whatever is the default behavior. What I find is 24/25/24 basis functions for jobs 1/2/3. That means the default for this basis is pure spherical harmonics for d functions (i.e., the oxygen gets 1 extra function when Cartesians are requested). You should be able to figure it out this way.
Thank you John. I will give it a try. Perhaps the team could pur the information on what is the default in the next release.
