Hello everyone,
I tried running a singlet excited state geometry optimisation in TD-DFT, using wB97M-V and the basis set def2-SVP. At the top of the output, after the references and the declaration of the environment where Q-Chem 5.4 is started, I get the following warning:
!!******************Warning*******************.
!!Desired Analytical derivatives not available.
!!Finite difference job might take a long time.
It seems to me that the diagnosis is quite simple: for wB97M-V, analytical gradients are not available, because by using a different functional (PBE). I want to understand if I’m doing anything wrong, since this is one of the very first excited state geometry optimisations I’m running. I am also curious if there are other modern range separated hybrid (RSH) functionals that are supported in Q-Chem for such kind of task.
Thank you for your time
I wish everybody a good day!
