Hello, did you have meet the problem of s2Ints != 0 in the SCF calculation? what is the solution for this problem? Thanks.
Input and Output as
User input:
mem_total 16000
mem_static 10000
method wb97x-D3
basis def2-SVP
ECP def2-ecp
thresh 14
scf_algorithm sgm
symmetry false
sym_ignore true
scf_guess read
os_roscf true ! Turns ROKS on
scf_convergence 5
max_scf_cycles 5000
!rel_x2c 1 ! Do X2C relativistic one-electron Hamiltonian
!rel_x2c_fd_displacement 100 ! Controls the finite difference step for W (default = 100 * 1e-6 = 1e-4)
Adding empirical dispersion correction
Doing -D3(0) with
s6 = 1.00000
s8 = 1.00000
rs6 = 1.28100
rs8 = 1.09400
-D3 energy without 3body term = -0.0119876589 hartrees
I Atom X Y Z
1 V 1.4742175699 0.0146030124 0.0027648813
2 Cl 2.2042109057 2.0415989630 0.0053454773
3 Cl 2.0211377686 -1.0679456264 -1.7805388256
4 Cl 2.0177581490 -1.0647791143 1.7890842308
5 N -0.1070633004 0.0772961109 0.0019981054
6 C -1.4907203283 0.0397485066 -0.0003658014
7 C -2.1980682907 1.2568772457 0.0016959433
8 C -3.5879097986 1.1870031842 0.0023906128
9 C -4.2400367517 -0.0415862807 0.0005323548
10 C -3.5156552832 -1.2298301763 -0.0019312265
11 C -2.1246507250 -1.2183706929 -0.0021598427
12 C -1.4653577734 2.5690125132 0.0031302823
13 C -1.3182099327 -2.4877761738 -0.0039326263
14 H -4.1623630389 2.1087505157 0.0040243862
15 H -5.3254093356 -0.0741419656 0.0010319819
16 H -4.0358535592 -2.1831776227 -0.0034528084
17 H -2.1669781398 3.4052384299 -0.0000876765
18 H -0.8223170178 2.6626996237 0.8837983894
19 H -0.8169547772 2.6613476531 -0.8736515466
20 H -0.6730248174 -2.5445369092 -0.8859871450
21 H -0.6723167072 -2.5465945902 0.8774743795
22 H -1.9729109921 -3.3612851219 -0.0046397591
Nuclear Repulsion Energy = 1406.66632901 hartrees
There are 69 alpha and 69 beta electrons
Requested basis set is def2-SVP
There are 116 shells and 256 basis functions
Q-Chem warning in module libmdc/get_mega.C, line 170:
Allowed MEM_STATIC has been capped at MEM_STATIC=8191.
Reduce the value of MEM_STATIC to silence this warning.
Total QAlloc Memory Limit 16000 MB
Mega-Array Size 8007 MB
MEM_STATIC part 8191 MB
A cutoff of 1.0D-14 yielded 5774 shell pairs
There are 27840 function pairs ( 31627 Cartesian)
Smallest overlap matrix eigenvalue = 2.11E-04
Scale SEOQF with 1.000000e-02/1.000000e-01/1.000000e-01
Nucleus-field energy = 0.0000000107 hartrees
Guess MOs from SCF MO coefficient file
Bang C. Huynh
Exchange: 0.1957 Hartree-Fock + 1.0000 wB97X-D3 + LR-HF
Correlation: 1.0000 wB97X-D3
Dispersion: Grimme D3
ROSCF Subspace Ranks:
Number of Active Doubly Occupied Levels: 68
Number of Frozen Doubly Occupied Levels: 0
Number of Active Singly Occupied Alpha Levels 1
Number of Frozen Singly Occupied Alpha Levels 0
Number of Active Singly Occupied Beta Levels 1
Number of Frozen Singly Occupied Beta Levels 0
Number of Active Virtual Levels: 186
Number of Frozen Virtual Levels: 0
Number of Active Singly Occupied Alpha Levels 2
Number of Active Singly Occupied Beta Levels 0
Orthonormalizing orbitals
using 48 threads for integral computing
Guess energy = -2488.3651161697
A restricted open-shell singlet SCF calculation will be
performed using SGM
Cycle Energy RMS Gradient
Delta = 1.332381472
Using OS-ROSCF Gradient
Fro norm of D 1.353826815243
transformation scaled by 2
1 -2488.3651161697 1.42e-02 Descent step
Delta = 7.002043700e+00
2 -2487.9768526228 3.26e-02 Line search: overstep
Delta = 3.880156649e-01
Fro norm of D 1.068101216492e+00
3 -2488.4234435255 7.68e-03 Descent step
Delta = 9.970177554e+02
4 -2487.7969519963 3.89e-01 Line search: overstep
Delta = 6.661437999e-01
5 -2488.4278010852 1.01e-02 Line search: overstep
Delta = 3.284383381e-01
Fro norm of D 1.373744649251e+00
6 -2488.4276426542 7.07e-03 Descent step
Delta = 4.586527693e+02
7 -2486.2506305386 2.64e-01 Line search: overstep
Delta = 4.487920283e+00
8 -2488.3410039975 2.61e-02 Line search: overstep
Delta = 3.019147969e-01
Fro norm of D 1.049851730437e+00
9 -2488.4283216076 6.77e-03 Descent step
Delta = 1.073329877e+03
10 -2486.3044714073 4.04e-01 Line search: overstep
Delta = 2.682805365e+00
11 -2488.3829547687 2.02e-02 Line search: overstep
Delta = 2.954470809e-01
12 -2488.4287647490 6.70e-03 Descent step
Delta = 2.464493901e+02
13 -2486.1567317336 1.94e-01 Line search: overstep
Delta = 1.985689108e+00
14 -2488.3942756454 1.74e-02 Line search: overstep
Delta = 2.845541911e-01
15 -2488.4291804955 6.58e-03 Descent step
Delta = 2.661869390e+02
16 -2486.9963778161 2.01e-01 Line search: overstep
Delta = 1.114429441e+00
17 -2488.4142259922 1.30e-02 Line search: overstep
Delta = 2.771788502e-01
18 -2488.4295653584 6.49e-03 Descent step
Delta = 1.105829403e+02
19 -2487.4087040065 1.30e-01 Line search: overstep
Delta = 7.535259868e-01
20 -2488.4210794956 1.07e-02 Line search: overstep
Delta = 2.706109839e-01
21 -2488.4298953566 6.41e-03 Descent step
Delta = 6.392280441e+01
22 -2487.8795275548 9.86e-02 Line search: overstep
Delta = 4.932377918e-01
23 -2488.4269062854 8.66e-03 Line search: overstep
Delta = 2.641953142e-01
24 -2488.4302744924 6.34e-03 Descent step
Delta = 3.357196765e+01
25 -2487.9458388565 7.14e-02 Line search: overstep
Delta = 4.446514984e-01
26 -2488.4274824224 8.22e-03 Line search: overstep
Delta = 2.583882638e-01
27 -2488.4305690783 6.27e-03 Descent step
Delta = 1.883269542e+01
28 -2488.1810029123 5.35e-02 Line search: overstep
Delta = 3.379920506e-01
29 -2488.4299393179 7.17e-03 Line search: overstep
Delta = 2.527207131e-01
30 -2488.4309061673 6.20e-03 Descent step
Delta = 1.209211542e+01
31 -2488.2168471443 4.29e-02 Line search: overstep
Delta = 3.156903590e-01
32 -2488.4302412113 6.93e-03 Line search: overstep
Delta = 2.475631650e-01
33 -2488.4311700003 6.13e-03 Descent step
Delta = 6.689813567e+00
34 -2488.3240446533 3.19e-02 Line search: overstep
Delta = 2.714694841e-01
35 -2488.4313241654 6.42e-03 Line search: overstep
Delta = 2.425279942e-01
36 -2488.4314720100 6.07e-03 Descent step
Delta = 4.918602369e+00
37 -2488.3404233737 2.73e-02 Line search: overstep
Delta = 2.605597446e-01
38 -2488.4315221058 6.29e-03 Line search: overstep
Delta = 2.379273273e-01
39 -2488.4317093264 6.01e-03 Descent step
Delta = 2.698991373e+00
40 -2488.3875935502 2.03e-02 Line search: overstep
Delta = 2.417338315e-01
41 -2488.4320447144 6.06e-03 Line search: overstep
Delta = 2.334324103e-01
42 -2488.4319814844 5.96e-03 Descent step
Delta = 2.137173760e+00
43 -2488.3945234727 1.80e-02 Line search: overstep
Delta = 2.355449297e-01
44 -2488.4322142237 5.98e-03 Line search: overstep
Delta = 2.293104904e-01
45 -2488.4321959669 5.90e-03 Descent step
Delta = 1.204011140e+00
46 -2488.4147922909 1.35e-02 Line search: overstep
Delta = 2.268998865e-01
47 -2488.4325098898 5.87e-03 Descent step
Delta = 1.658797506e+00
48 -2488.4028329756 1.59e-02 Line search: overstep
Delta = 2.215219872e-01
49 -2488.4327304524 5.80e-03 Descent step
Delta = 1.285404720e+00
50 -2488.4116857199 1.40e-02 Line search: overstep
Delta = 2.179016439e-01
51 -2488.4329380995 5.76e-03 Descent step
Delta = 1.076516070e+00
52 -2488.4156021482 1.28e-02 Line search: overstep
Delta = 2.141318518e-01
53 -2488.4331233971 5.71e-03 Descent step
Delta = 8.537500229e-01
54 -2488.4208260365 1.14e-02 Line search: overstep
Delta = 2.106369914e-01
55 -2488.4333112182 5.66e-03 Descent step
Delta = 6.944364650e-01
56 -2488.4239479493 1.03e-02 Line search: overstep
Delta = 2.075444424e-01
57 -2488.4334784264 5.62e-03 Descent step
Delta = 5.671669010e-01
58 -2488.4269400210 9.29e-03 Line search: overstep
Delta = 2.044778400e-01
59 -2488.4336455914 5.58e-03 Descent step
Delta = 4.545508438e-01
60 -2488.4291974578 8.31e-03 Line search: overstep
Delta = 2.017447630e-01
61 -2488.4337988160 5.54e-03 Descent step
Delta = 3.793442702e-01
62 -2488.4309857803 7.59e-03 Line search: overstep
Delta = 1.990797805e-01
63 -2488.4339565030 5.50e-03 Descent step
Delta = 3.355464714e-01
64 -2488.4317987318 7.14e-03 Line search: overstep
Delta = 1.965897166e-01
65 -2488.4341045124 5.47e-03 Descent step
Delta = 3.072539956e-01
66 -2488.4325016681 6.83e-03 Line search: overstep
Delta = 1.941408804e-01
67 -2488.4342508081 5.43e-03 Descent step
Delta = 2.784229788e-01
68 -2488.4330557852 6.51e-03 Line search: overstep
Delta = 1.918449884e-01
69 -2488.4343886935 5.40e-03 Descent step
Delta = 2.597973515e-01
70 -2488.4335322313 6.28e-03 Line search: overstep
Delta = 1.895851431e-01
71 -2488.4345250186 5.37e-03 Descent step
Delta = 2.407782257e-01
72 -2488.4339155879 6.05e-03 Line search: overstep
Delta = 1.874592762e-01
73 -2488.4346539712 5.34e-03 Descent step
Delta = 2.283628314e-01
74 -2488.4342478273 5.89e-03 Line search: overstep
Delta = 1.853651094e-01
75 -2488.4347815230 5.31e-03 Descent step
Delta = 2.157278903e-01
76 -2488.4345200194 5.73e-03 Line search: overstep
Delta = 1.833885438e-01
77 -2488.4349025772 5.28e-03 Descent step
Delta = 2.073186075e-01
78 -2488.4347601148 5.61e-03 Line search: overstep
Delta = 1.814400245e-01
79 -2488.4350223718 5.25e-03 Descent step
Delta = 1.988185968e-01
80 -2488.4349605030 5.50e-03 Line search: overstep
Delta = 1.795949569e-01
81 -2488.4351364187 5.22e-03 Descent step
Delta = 1.929979869e-01
82 -2488.4351416068 5.42e-03 Line search: overstep
Delta = 1.777748600e-01
83 -2488.4352493268 5.20e-03 Descent step
Delta = 1.871688269e-01
84 -2488.4352958455 5.33e-03 Line search: overstep
Delta = 1.760460520e-01
85 -2488.4353571445 5.17e-03 Descent step
Delta = 1.830220884e-01
86 -2488.4354391141 5.27e-03 Line search: overstep
Delta = 1.743396892e-01
87 -2488.4354639296 5.15e-03 Descent step
Delta = 1.789139557e-01
88 -2488.4355637192 5.22e-03 Line search: overstep
Delta = 1.727140195e-01
89 -2488.4355661964 5.12e-03 Descent step
Delta = 1.758506725e-01
90 -2488.4356825784 5.17e-03 Line search: overstep
Delta = 1.711086018e-01
91 -2488.4356675169 5.10e-03 Descent step
Delta = 1.728505603e-01
92 -2488.4357880989 5.13e-03 Line search: overstep
Delta = 1.695746776e-01
93 -2488.4357648104 5.08e-03 Descent step
Delta = 1.704898767e-01
94 -2488.4358910267 5.09e-03 Line search: overstep
Delta = 1.680591553e-01
95 -2488.4358612089 5.05e-03 Descent step
Delta = 1.682030596e-01
96 -2488.4359841932 5.06e-03 Descent step
Delta = 1.648370591e-01
97 -2488.4361072187 5.01e-03 Descent step
Delta = 1.647162259e-01
98 -2488.4361798259 5.00e-03 Descent step
Delta = 1.623878068e-01
99 -2488.4362837585 4.97e-03 Descent step
Delta = 1.618372513e-01
100 -2488.4363553002 4.96e-03 Descent step
Delta = 1.599817877e-01
101 -2488.4364496403 4.93e-03 Descent step
Delta = 1.592277164e-01
102 -2488.4365205566 4.92e-03 Descent step
Delta = 1.576364094e-01
103 -2488.4366086819 4.90e-03 Descent step
Delta = 1.567896092e-01
104 -2488.4366783265 4.88e-03 Descent step
Delta = 1.553630579e-01
105 -2488.4367618600 4.86e-03 Descent step
Delta = 1.544796161e-01
106 -2488.4368298222 4.85e-03 Descent step
Delta = 1.531655444e-01
107 -2488.4369096722 4.83e-03 Descent step
Delta = 1.522742015e-01
108 -2488.4369757796 4.81e-03 Descent step
Delta = 1.510432094e-01
109 -2488.4370525149 4.79e-03 Descent step
Delta = 1.501586288e-01
110 -2488.4371167254 4.78e-03 Descent step
Delta = 1.489931974e-01
111 -2488.4371907242 4.76e-03 Descent step
Delta = 1.481226451e-01
112 -2488.4372530675 4.75e-03 Descent step
Delta = 1.470117322e-01
113 -2488.4373246002 4.73e-03 Descent step
Delta = 1.461585368e-01
114 -2488.4373851391 4.71e-03 Descent step
Delta = 1.450947813e-01
115 -2488.4374544184 4.70e-03 Descent step
Delta = 1.442601822e-01
116 -2488.4375132390 4.68e-03 Descent step
Delta = 1.432383867e-01
117 -2488.4375804327 4.67e-03 Descent step
Delta = 1.424225138e-01
118 -2488.4376376206 4.65e-03 Descent step
Delta = 1.414388164e-01
119 -2488.4377028699 4.64e-03 Descent step
Delta = 1.406412300e-01
120 -2488.4377585104 4.62e-03 Descent step
Delta = 1.396926185e-01
121 -2488.4378219354 4.61e-03 Descent step
Delta = 1.389126065e-01
122 -2488.4378761095 4.60e-03 Descent step
Delta = 1.379966339e-01
123 -2488.4379378141 4.58e-03 Descent step
Delta = 1.372333748e-01
124 -2488.4379905979 4.57e-03 Descent step
Delta = 1.363479848e-01
125 -2488.4380506750 4.55e-03 Descent step
Delta = 1.356006363e-01
126 -2488.4381021398 4.54e-03 Descent step
Delta = 1.347440531e-01
127 -2488.4381606731 4.53e-03 Descent step
Delta = 1.340117985e-01
128 -2488.4382108843 4.51e-03 Descent step
Delta = 1.331824570e-01
129 -2488.4382679499 4.50e-03 Descent step
Delta = 1.324645280e-01
130 -2488.4383169680 4.49e-03 Descent step
Delta = 1.316610270e-01
131 -2488.4383726346 4.47e-03 Descent step
Delta = 1.309567127e-01
132 -2488.4384205158 4.46e-03 Descent step
Delta = 1.301777806e-01
133 -2488.4384748482 4.45e-03 Descent step
Delta = 1.294864302e-01
134 -2488.4385216446 4.44e-03 Descent step
Delta = 1.287309019e-01
135 -2488.4385747027 4.42e-03 Descent step
Delta = 1.280519238e-01
136 -2488.4386204629 4.41e-03 Descent step
Delta = 1.273187245e-01
137 -2488.4386723021 4.40e-03 Descent step
Delta = 1.266515809e-01
138 -2488.4387170711 4.39e-03 Descent step
Delta = 1.259397129e-01
139 -2488.4387677431 4.38e-03 Descent step
Delta = 1.252839144e-01
140 -2488.4388115630 4.36e-03 Descent step
Delta = 1.245924464e-01
141 -2488.4388611175 4.35e-03 Descent step
Delta = 1.239475490e-01
142 -2488.4389040276 4.34e-03 Descent step
Delta = 1.232756107e-01
143 -2488.4389525098 4.33e-03 Descent step
Delta = 1.226412093e-01
144 -2488.4389945466 4.32e-03 Descent step
Delta = 1.219879825e-01
145 -2488.4390419996 4.31e-03 Descent step
Delta = 1.213637060e-01
146 -2488.4390831979 4.30e-03 Descent step
Delta = 1.207284187e-01
147 -2488.4391296634 4.28e-03 Descent step
Delta = 1.201139280e-01
148 -2488.4391700556 4.27e-03 Descent step
Delta = 1.194958546e-01
149 -2488.4392155715 4.26e-03 Descent step
Delta = 1.188908371e-01
150 -2488.4392551880 4.25e-03 Descent step
Delta = 1.182892900e-01
151 -2488.4392997901 4.24e-03 Descent step
Delta = 1.176934552e-01
152 -2488.4393386601 4.23e-03 Descent step
Delta = 1.171077802e-01
153 -2488.4393823853 4.22e-03 Descent step
Delta = 1.165208620e-01
154 -2488.4394205362 4.21e-03 Descent step
Delta = 1.159504432e-01
155 -2488.4394634162 4.20e-03 Descent step
Delta = 1.153721934e-01
156 -2488.4395008743 4.19e-03 Descent step
Delta = 1.148164380e-01
157 -2488.4395429417 4.18e-03 Descent step
Delta = 1.142466206e-01
158 -2488.4395797310 4.17e-03 Descent step
Delta = 1.137049777e-01
159 -2488.4396210146 4.16e-03 Descent step
Delta = 1.131433693e-01
160 -2488.4396571592 4.15e-03 Descent step
Delta = 1.126153081e-01
161 -2488.4396976881 4.14e-03 Descent step
Delta = 1.120617014e-01
162 -2488.4397332104 4.13e-03 Descent step
Delta = 1.115467158e-01
163 -2488.4397730114 4.12e-03 Descent step
Delta = 1.110009152e-01
164 -2488.4398079328 4.11e-03 Descent step
Delta = 1.104985199e-01
165 -2488.4398470332 4.10e-03 Descent step
Delta = 1.099603399e-01
166 -2488.4398813744 4.09e-03 Descent step
Delta = 1.094700773e-01
167 -2488.4399197984 4.08e-03 Descent step
Delta = 1.089393384e-01
168 -2488.4399535782 4.07e-03 Descent step
Delta = 1.084607723e-01
169 -2488.4399913482 4.06e-03 Descent step
Delta = 1.079373002e-01
170 -2488.4400245856 4.05e-03 Descent step
Delta = 1.074700076e-01
171 -2488.4400617291 4.04e-03 Descent step
Delta = 1.069536485e-01
172 -2488.4400944436 4.03e-03 Descent step
Delta = 1.064972256e-01
173 -2488.4401309775 4.02e-03 Descent step
Delta = 1.059878236e-01
174 -2488.4401631844 4.01e-03 Descent step
Delta = 1.055418825e-01
175 -2488.4401991328 4.01e-03 Descent step
Delta = 1.050392905e-01
176 -2488.4402308499 4.00e-03 Descent step
Delta = 1.046034673e-01
177 -2488.4402662312 3.99e-03 Descent step
Delta = 1.041075395e-01
178 -2488.4402974731 3.98e-03 Descent step
Delta = 1.036814772e-01
179 -2488.4403323073 3.97e-03 Descent step
Delta = 1.031920809e-01
180 -2488.4403630900 3.96e-03 Descent step
Delta = 1.027754368e-01
181 -2488.4403974000 3.95e-03 Descent step
Delta = 1.022924371e-01
182 -2488.4404277394 3.94e-03 Descent step
Delta = 1.018848955e-01
183 -2488.4404615387 3.94e-03 Descent step
Delta = 1.014081563e-01
184 -2488.4404914473 3.93e-03 Descent step
Delta = 1.010094114e-01
185 -2488.4405247528 3.92e-03 Descent step
Delta = 1.005388036e-01
186 -2488.4405542436 3.91e-03 Descent step
Delta = 1.001485624e-01
187 -2488.4405870702 3.90e-03 Descent step
Delta = 9.968395978e-02
188 -2488.4406161567 3.89e-03 Descent step
Delta = 9.930193970e-02
189 -2488.4406485213 3.89e-03 Descent step
Delta = 9.884322418e-02
190 -2488.4406772163 3.88e-03 Descent step
Delta = 9.846915114e-02
191 -2488.4407091343 3.87e-03 Descent step
Delta = 9.801620841e-02
192 -2488.4407374496 3.86e-03 Descent step
Delta = 9.764981947e-02
193 -2488.4407689354 3.85e-03 Descent step
Delta = 9.720253938e-02
194 -2488.4407968831 3.84e-03 Descent step
Delta = 9.684358094e-02
195 -2488.4408279508 3.84e-03 Descent step
Delta = 9.640185683e-02
196 -2488.4408555415 3.83e-03 Descent step
Delta = 9.605008583e-02
197 -2488.4408862041 3.82e-03 Descent step
Delta = 9.561381328e-02
198 -2488.4409134483 3.81e-03 Descent step
Delta = 9.526899782e-02
199 -2488.4409437185 3.81e-03 Descent step
Delta = 9.483807131e-02
200 -2488.4409706271 3.80e-03 Descent step
Delta = 9.449999128e-02
201 -2488.4410005180 3.79e-03 Descent step
Delta = 9.407430895e-02
202 -2488.4410271013 3.78e-03 Descent step
Delta = 9.374275213e-02
203 -2488.4410566249 3.77e-03 Descent step
Delta = 9.332221463e-02
204 -2488.4410828922 3.77e-03 Descent step
Delta = 9.299697720e-02
205 -2488.4411120593 3.76e-03 Descent step
Delta = 9.258148784e-02
206 -2488.4411380199 3.75e-03 Descent step
Delta = 9.226237284e-02
207 -2488.4411668410 3.74e-03 Descent step
Delta = 9.185183735e-02
208 -2488.4411925032 3.74e-03 Descent step
Delta = 9.153865691e-02
209 -2488.4412209887 3.73e-03 Descent step
Delta = 9.113298220e-02
210 -2488.4412463608 3.72e-03 Descent step
Delta = 9.082555738e-02
211 -2488.4412745210 3.72e-03 Descent step
Delta = 9.042465194e-02
212 -2488.4412996119 3.71e-03 Descent step
Delta = 9.012281107e-02
213 -2488.4413274558 3.70e-03 Descent step
Delta = 8.972658527e-02
214 -2488.4413522732 3.69e-03 Descent step
Delta = 8.943016189e-02
215 -2488.4413798092 3.69e-03 Descent step
Delta = 8.903852874e-02
216 -2488.4414043597 3.68e-03 Descent step
Delta = 8.874736179e-02
217 -2488.4414315970 3.67e-03 Descent step
Delta = 8.836023851e-02
218 -2488.4414558892 3.66e-03 Descent step
Delta = 8.807417337e-02
219 -2488.4414828389 3.66e-03 Descent step
Delta = 8.769147983e-02
220 -2488.4415068814 3.65e-03 Descent step
Delta = 8.741036715e-02
221 -2488.4415335514 3.65e-03 Descent step
Delta = 8.703202412e-02
222 -2488.4415573507 3.64e-03 Descent step
Delta = 8.675572027e-02
223 -2488.4415837471 3.63e-03 Descent step
Delta = 8.638164732e-02
224 -2488.4416073080 3.62e-03 Descent step
Delta = 8.611001754e-02
225 -2488.4416334366 3.62e-03 Descent step
Delta = 8.574013843e-02
226 -2488.4416567653 3.61e-03 Descent step
Delta = 8.547305041e-02
227 -2488.4416826357 3.60e-03 Descent step
Delta = 8.510729041e-02
228 -2488.4417057397 3.60e-03 Descent step
Delta = 8.484461704e-02
229 -2488.4417313591 3.59e-03 Descent step
Delta = 8.448290365e-02
230 -2488.4417542443 3.58e-03 Descent step
Delta = 8.422452205e-02
231 -2488.4417796192 3.58e-03 Descent step
Delta = 8.386678482e-02
232 -2488.4418022884 3.57e-03 Descent step
Delta = 8.361257680e-02
233 -2488.4418274233 3.57e-03 Descent step
Delta = 8.325874660e-02
234 -2488.4418498841 3.56e-03 Descent step
Delta = 8.300859720e-02
235 -2488.4418747863 3.55e-03 Descent step
Delta = 8.265860753e-02
236 -2488.4418970434 3.54e-03 Descent step
Delta = 8.241240721e-02
237 -2488.4419217188 3.54e-03 Descent step
Delta = 8.206619214e-02
238 -2488.4419437771 3.53e-03 Descent step
Delta = 8.182383689e-02
239 -2488.4419682311 3.53e-03 Descent step
Delta = 8.148132953e-02
240 -2488.4419900958 3.52e-03 Descent step
Delta = 8.124271950e-02
241 -2488.4420143340 3.51e-03 Descent step
Delta = 8.090385563e-02
Q-Chem fatal error occurred in module forms2/ShlPairs.C, line 54:
In ~ShlPairs: s2Ints != 0.
