Trying to evaluate performance of SOC calculations in TD-DFT methods
We are currently trying to perform SOC computation on silicon quantum dots with the TD-DFT method and we wanted to evaluate the soundness of the results.
After trying a calculation using the B3LYP/def2-SVP method on a Ca atom and comparing it to the NIST values, the results appear to be quite bad.
This is the input we’ve used for the calculation:
Ca 0.0 0.0 0.0
   MEM_TOTAL            1000
   MEM_STATIC           200
   JOBTYPE              sp
   EXCHANGE             b3lyp
   BASIS                def2-svp
   SCF_ALGORITHM        diis
   MAX_SCF_CYCLES       100
   CIS_N_ROOTS          5
   CIS_SINGLETS         true
   CIS_TRIPLETS         true
   STS_MOM              true
   CALC_SOC             true
   IQMOL_FCHK           True
This is the output of the calculation:
    1      Ca      0.0000000000     0.0000000000     0.0000000000
 Molecular Point Group                 Kh    NOp =***
 Largest Abelian Subgroup              D2h   NOp =  1
 Nuclear Repulsion Energy =           0.00000000 hartrees
 There are       10 alpha and       10 beta electrons
 Requested basis set is def2-SVP
 There are 10 shells and 24 basis functions
 Total QAlloc Memory Limit   1000 MB
 Mega-Array Size       196 MB
 MEM_STATIC part       200 MB
 A cutoff of  1.0D-11 yielded     55 shell pairs
 There are       329 function pairs (       390 Cartesian)
 Smallest overlap matrix eigenvalue = 1.22E-01
 Warning:  Energy on first SCF cycle will be non-variational
 SAD guess density has 20.000000 electrons
  Bang C. Huynh
 Exchange:     0.2000 Hartree-Fock + 0.0800 Slater + 0.7200 B88
 Correlation:  0.1900 VWN1RPA + 0.8100 LYP
 using 2 threads for integral computing
 performed using DIIS
  Cycle       Energy         DIIS error
    1    -677.4893010978      4.24e-03
    2    -677.4910087559      2.49e-04
    3    -677.4910160572      2.93e-05
    4    -677.4910161880      1.33e-06
    5    -677.4910161882      4.10e-09  Convergence criterion met
 SCF time:   CPU 0.60s  wall 1.00s
 SCF   energy in the final basis set =     -677.4910161882
 Total energy in the final basis set =     -677.4910161882
 Direct TDDFT/TDA calculation will be performed
 Triplet excitation energies requested
 Singlet excitation energies requested
 CIS energy converged when residual is below 10e- 6
 Iter    Rts Conv    Rts Left    Ttl Dev     Max Dev
   1         0           5      0.002607    0.000521
   2         0           5      0.000161    0.000032
   3         0           5      0.000007    0.000001
   4         5           0      0.000000    0.000000    Roots Converged
 Triplets done: starting singlet calculation
   5         0           5      0.005365    0.001073
   6         0           5      0.000724    0.000145
   7         0           5      0.000013    0.000003
   8         5           0      0.000000    0.000000    Roots Converged
         TDDFT/TDA Excitation Energies
 Excited state   1: excitation energy (eV) =    1.7838
 Total energy for state  1:                  -677.42546272 au
    Multiplicity: Triplet
    Trans. Mom.:  0.0000 X   0.0000 Y   0.0000 Z
    Strength   :     0.0000000000
    D(   10) --> V(    2) amplitude =  0.9999
 Excited state   2: excitation energy (eV) =    1.7838
 Total energy for state  2:                  -677.42546272 au
    D(   10) --> V(    1) amplitude =  0.9999
 Excited state   3: excitation energy (eV) =    1.7838
 Total energy for state  3:                  -677.42546272 au
    D(   10) --> V(    4) amplitude =  0.9999
 Excited state   4: excitation energy (eV) =    1.7838
 Total energy for state  4:                  -677.42546272 au
    D(   10) --> V(    3) amplitude =  0.9999
 Excited state   5: excitation energy (eV) =    1.7838
 Total energy for state  5:                  -677.42546272 au
    D(   10) --> V(    5) amplitude =  0.9999
 Excited state   6: excitation energy (eV) =    2.2924
 Total energy for state  6:                  -677.40677104 au
    Multiplicity: Singlet
    Trans. Mom.: -0.0000 X  -0.0000 Y   0.0000 Z
    D(   10) --> V(    1) amplitude =  0.9985
 Excited state   7: excitation energy (eV) =    2.2924
 Total energy for state  7:                  -677.40677104 au
    Trans. Mom.:  0.0000 X  -0.0000 Y   0.0000 Z
    D(   10) --> V(    2) amplitude =  0.9985
 Excited state   8: excitation energy (eV) =    2.2924
 Total energy for state  8:                  -677.40677104 au
    D(   10) --> V(    3) amplitude =  0.9985
 Excited state   9: excitation energy (eV) =    2.2924
 Total energy for state  9:                  -677.40677104 au
    Trans. Mom.:  0.0000 X   0.0000 Y  -0.0000 Z
    D(   10) --> V(    4) amplitude =  0.9985
 Excited state  10: excitation energy (eV) =    2.2924
 Total energy for state 10:                  -677.40677104 au
    D(   10) --> V(    5) amplitude =  0.9985
  SETman timing summary (seconds)
  CPU time                 1.09s
  System time              0.00s
  Wall time                0.66s
*********SPIN-ORBIT COUPLING JOB BEGINS HERE*********
    SPIN-ORBIT COUPLING BETWEEN THE SINGLET GROUND STATE AND EXCITED TRIPLET STATE
SOC between the singlet ground state and excited triplet states (ms=0):
T1(ms=0)      0.000000  +  0.000000i    cm-1
T2(ms=0)      0.000000  +  0.000000i    cm-1
T3(ms=0)      0.000000  +  -0.000000i    cm-1
T4(ms=0)      0.000000  +  0.000000i    cm-1
T5(ms=0)      0.000000  +  0.000000i    cm-1
SOC between the singlet ground state and excited triplet states (ms=1):
T1(ms=1)      -0.000000  + (-0.000000i)    cm-1
T2(ms=1)      -0.000000  + (-0.000000i)    cm-1
T3(ms=1)      -0.000000  + (0.000000i)    cm-1
T4(ms=1)      0.000000  + (0.000000i)    cm-1
T5(ms=1)      0.000000  + (-0.000000i)    cm-1
SOC between the singlet ground state and excited triplet states (ms=-1):
T1(ms=-1)     -0.000000  - (-0.000000i)    cm-1
T2(ms=-1)     -0.000000  - (-0.000000i)    cm-1
T3(ms=-1)     -0.000000  - (0.000000i)    cm-1
T4(ms=-1)     0.000000  - (0.000000i)    cm-1
T5(ms=-1)     0.000000  - (-0.000000i)    cm-1
Total SOC between the singlet ground state and excited triplet states:
T1      0.000000    cm-1
T2      0.000000    cm-1
T3      0.000000    cm-1
T4      0.000000    cm-1
T5      0.000000    cm-1
                     SPIN-ORBIT COUPLING BETWEEN EXCITED TRIPLET STATES
SOC between the T1 (ms=0) state and excited triplet states (ms=1):
T2(ms=1)      -39.185965  + (0.000091i)    cm-1
T3(ms=1)      -0.000179  + (-21.540613i)    cm-1
T4(ms=1)      0.000001  + (0.000345i)    cm-1
T5(ms=1)      17.901179  + (-0.000003i)    cm-1
SOC between the T1 (ms=0) state and excited triplet states (ms=-1):
T2(ms=-1)     39.185965  + (0.000091i)    cm-1
T3(ms=-1)     0.000179  + (-21.540613i)    cm-1
T4(ms=-1)     -0.000001  + (0.000345i)    cm-1
T5(ms=-1)     -17.901179  + (-0.000003i)    cm-1
SOC between the T1 (ms=1) state and excited triplet states (ms=0):
T2(ms=0)      39.185965  + (0.000091i)    cm-1
T3(ms=0)      0.000179  + (-21.540613i)    cm-1
T4(ms=0)      -0.000001  + (0.000345i)    cm-1
T5(ms=0)      -17.901179  + (-0.000003i)    cm-1
SOC between the T1 (ms=1) state and excited triplet states (ms=1):
T2(ms=1)      0.000000  + (-0.000048i)    cm-1
T3(ms=1)      0.000000  + (0.000519i)    cm-1
T4(ms=1)      0.000000  + (30.463028i)    cm-1
T5(ms=1)      0.000000  + (-0.000056i)    cm-1
SOC between the T1 (ms=-1) state and excited triplet states (ms=0):
T2(ms=0)      -39.185965  + (0.000091i)    cm-1
T3(ms=0)      -0.000179  + (-21.540613i)    cm-1
T4(ms=0)      0.000001  + (0.000345i)    cm-1
T5(ms=0)      17.901179  + (-0.000003i)    cm-1
SOC between the T1 (ms=-1) state and excited triplet states (ms=-1):
T2(ms=-1)     0.000000  + (0.000048i)    cm-1
T3(ms=-1)     0.000000  + (-0.000519i)    cm-1
T4(ms=-1)     0.000000  + (-30.463028i)    cm-1
T5(ms=-1)     0.000000  + (0.000056i)    cm-1
Total SOC between the T1 state and excited triplet states:
T2      78.371931    cm-1
T3      43.081227    cm-1
T4      43.081227    cm-1
T5      35.802358    cm-1
SOC between the T2 (ms=0) state and excited triplet states (ms=1):
T3(ms=1)      -0.000014  + (-0.000581i)    cm-1
T4(ms=1)      0.000103  + (-35.095859i)    cm-1
T5(ms=1)      -0.000013  + (0.000060i)    cm-1
SOC between the T2 (ms=0) state and excited triplet states (ms=-1):
T3(ms=-1)     0.000014  + (-0.000581i)    cm-1
T4(ms=-1)     -0.000103  + (-35.095859i)    cm-1
T5(ms=-1)     0.000013  + (0.000060i)    cm-1
SOC between the T2 (ms=1) state and excited triplet states (ms=0):
T3(ms=0)      0.000014  + (-0.000581i)    cm-1
T4(ms=0)      -0.000103  + (-35.095859i)    cm-1
T5(ms=0)      0.000013  + (0.000060i)    cm-1
SOC between the T2 (ms=1) state and excited triplet states (ms=1):
T3(ms=1)      0.000000  + (-5.784285i)    cm-1
T4(ms=1)      0.000000  + (0.000086i)    cm-1
T5(ms=1)      0.000000  + (0.000273i)    cm-1
SOC between the T2 (ms=-1) state and excited triplet states (ms=0):
T3(ms=0)      -0.000014  + (-0.000581i)    cm-1
T4(ms=0)      0.000103  + (-35.095859i)    cm-1
T5(ms=0)      -0.000013  + (0.000060i)    cm-1
SOC between the T2 (ms=-1) state and excited triplet states (ms=-1):
T3(ms=-1)     0.000000  + (5.784285i)    cm-1
T4(ms=-1)     0.000000  + (-0.000086i)    cm-1
T5(ms=-1)     0.000000  + (-0.000273i)    cm-1
Total SOC between the T2 state and excited triplet states:
T3      8.180214    cm-1
T4      70.191717    cm-1
T5      0.000406    cm-1
SOC between the T3 (ms=0) state and excited triplet states (ms=1):
T4(ms=1)      -21.540613  + (-0.000156i)    cm-1
T5(ms=1)      0.000068  + (0.000415i)    cm-1
SOC between the T3 (ms=0) state and excited triplet states (ms=-1):
T4(ms=-1)     21.540613  + (-0.000156i)    cm-1
T5(ms=-1)     -0.000068  + (0.000415i)    cm-1
SOC between the T3 (ms=1) state and excited triplet states (ms=0):
T4(ms=0)      21.540613  + (-0.000156i)    cm-1
T5(ms=0)      -0.000068  + (0.000415i)    cm-1
SOC between the T3 (ms=1) state and excited triplet states (ms=1):
T4(ms=1)      0.000000  + (-0.000145i)    cm-1
T5(ms=1)      0.000000  + (-60.650855i)    cm-1
SOC between the T3 (ms=-1) state and excited triplet states (ms=0):
T4(ms=0)      -21.540613  + (-0.000156i)    cm-1
T5(ms=0)      0.000068  + (0.000415i)    cm-1
SOC between the T3 (ms=-1) state and excited triplet states (ms=-1):
T4(ms=-1)     0.000000  + (0.000145i)    cm-1
T5(ms=-1)     0.000000  + (60.650855i)    cm-1
Total SOC between the T3 state and excited triplet states:
T4      43.081227    cm-1
T5      85.773262    cm-1
SOC between the T4 (ms=0) state and excited triplet states (ms=1):
T5(ms=1)      0.000001  + (24.985452i)    cm-1
SOC between the T4 (ms=0) state and excited triplet states (ms=-1):
T5(ms=-1)     -0.000001  + (24.985452i)    cm-1
SOC between the T4 (ms=1) state and excited triplet states (ms=0):
T5(ms=0)      -0.000001  + (24.985452i)    cm-1
SOC between the T4 (ms=1) state and excited triplet states (ms=1):
T5(ms=1)      0.000000  + (0.001022i)    cm-1
SOC between the T4 (ms=-1) state and excited triplet states (ms=0):
T5(ms=0)      0.000001  + (24.985452i)    cm-1
SOC between the T4 (ms=-1) state and excited triplet states (ms=-1):
T5(ms=-1)     0.000000  + (-0.001022i)    cm-1
Total SOC between the T4 state and excited triplet states:
T5      49.970904    cm-1
         SPIN-ORBIT COUPLING BETWEEN EXCITED SINGLET STATES AND TRIPLET STATES
SOC between the S1 state and excited triplet states (ms=0):
T1(ms=0)      0.000000  +  0.000001i    cm-1
T2(ms=0)      0.000000  +  -0.000026i    cm-1
T3(ms=0)      0.000000  +  5.990486i    cm-1
T4(ms=0)      0.000000  +  -0.000012i    cm-1
T5(ms=0)      0.000000  +  -0.000007i    cm-1
SOC between the S1 state and excited triplet states (ms=1):
T1(ms=1)      (40.587926)  + (0.000004i)    cm-1
T2(ms=1)      (0.000100)  + (0.000058i)    cm-1
T3(ms=1)      (0.000021)  + (-0.000547i)    cm-1
T4(ms=1)      (0.000009)  + (-36.352013i)    cm-1
T5(ms=1)      (-0.000059)  + (0.000103i)    cm-1
SOC between the S1 state and excited triplet states (ms=-1):
T1(ms=-1)    -(40.587926)  + (0.000004i)    cm-1
T2(ms=-1)    -(0.000100)  + (0.000058i)    cm-1
T3(ms=-1)    -(0.000021)  + (-0.000547i)    cm-1
T4(ms=-1)    -(0.000009)  + (-36.352013i)    cm-1
T5(ms=-1)    -(-0.000059)  + (0.000103i)    cm-1
Total SOC between the S1 state and excited triplet states:
T1      57.399996    cm-1
T2      0.000166    cm-1
T3      5.990486    cm-1
T4      51.409510    cm-1
T5      0.000168    cm-1
SOC between the S2 state and excited triplet states (ms=0):
T1(ms=0)      0.000000  +  0.000010i    cm-1
T2(ms=0)      0.000000  +  0.000045i    cm-1
T3(ms=0)      0.000000  +  -0.000513i    cm-1
T4(ms=0)      0.000000  +  -31.553085i    cm-1
T5(ms=0)      0.000000  +  0.000106i    cm-1
SOC between the S2 state and excited triplet states (ms=1):
T1(ms=1)      (0.000103)  + (0.000017i)    cm-1
T2(ms=1)      (-40.588156)  + (0.000106i)    cm-1
T3(ms=1)      (-0.000178)  + (-22.311401i)    cm-1
T4(ms=1)      (-0.000016)  + (0.000272i)    cm-1
T5(ms=1)      (18.541737)  + (0.000006i)    cm-1
SOC between the S2 state and excited triplet states (ms=-1):
T1(ms=-1)    -(0.000103)  + (0.000017i)    cm-1
T2(ms=-1)    -(-40.588156)  + (0.000106i)    cm-1
T3(ms=-1)    -(-0.000178)  + (-22.311401i)    cm-1
T4(ms=-1)    -(-0.000016)  + (0.000272i)    cm-1
T5(ms=-1)    -(18.541737)  + (0.000006i)    cm-1
Total SOC between the S2 state and excited triplet states:
T1      0.000148    cm-1
T2      57.400320    cm-1
T3      31.553085    cm-1
T4      31.553085    cm-1
T5      26.221975    cm-1
SOC between the S3 state and excited triplet states (ms=0):
T1(ms=0)      0.000000  +  31.553085i    cm-1
T2(ms=0)      0.000000  +  0.000047i    cm-1
T3(ms=0)      0.000000  +  0.000056i    cm-1
T4(ms=0)      0.000000  +  0.000010i    cm-1
T5(ms=0)      0.000000  +  -0.000617i    cm-1
SOC between the S3 state and excited triplet states (ms=1):
T1(ms=1)      (-0.000002)  + (-0.000200i)    cm-1
T2(ms=1)      (-0.000094)  + (36.351693i)    cm-1
T3(ms=1)      (22.311401)  + (0.000169i)    cm-1
T4(ms=1)      (-0.000157)  + (0.000147i)    cm-1
T5(ms=1)      (-0.000005)  + (25.879506i)    cm-1
SOC between the S3 state and excited triplet states (ms=-1):
T1(ms=-1)    -(-0.000002)  + (-0.000200i)    cm-1
T2(ms=-1)    -(-0.000094)  + (36.351693i)    cm-1
T3(ms=-1)    -(22.311401)  + (0.000169i)    cm-1
T4(ms=-1)    -(-0.000157)  + (0.000147i)    cm-1
T5(ms=-1)    -(-0.000005)  + (25.879506i)    cm-1
Total SOC between the S3 state and excited triplet states:
T1      31.553085    cm-1
T2      51.409057    cm-1
T3      31.553085    cm-1
T4      0.000304    cm-1
T5      36.599148    cm-1
SOC between the S4 state and excited triplet states (ms=0):
T1(ms=0)      0.000000  +  0.000316i    cm-1
T2(ms=0)      0.000000  +  -5.991263i    cm-1
T3(ms=0)      0.000000  +  -0.000013i    cm-1
T4(ms=0)      0.000000  +  0.000174i    cm-1
T5(ms=0)      0.000000  +  62.821123i    cm-1
SOC between the S4 state and excited triplet states (ms=1):
T1(ms=1)      (0.000011)  + (22.311401i)    cm-1
T2(ms=1)      (0.000046)  + (0.000346i)    cm-1
T3(ms=1)      (-0.000157)  + (0.000017i)    cm-1
T4(ms=1)      (-22.311401)  + (0.000003i)    cm-1
T5(ms=1)      (0.000056)  + (0.000248i)    cm-1
SOC between the S4 state and excited triplet states (ms=-1):
T1(ms=-1)    -(0.000011)  + (22.311401i)    cm-1
T2(ms=-1)    -(0.000046)  + (0.000346i)    cm-1
T3(ms=-1)    -(-0.000157)  + (0.000017i)    cm-1
T4(ms=-1)    -(-22.311401)  + (0.000003i)    cm-1
T5(ms=-1)    -(0.000056)  + (0.000248i)    cm-1
Total SOC between the S4 state and excited triplet states:
T1      31.553085    cm-1
T2      5.991263    cm-1
T3      0.000224    cm-1
T4      31.553085    cm-1
T5      62.821123    cm-1
SOC between the S5 state and excited triplet states (ms=0):
T1(ms=0)      0.000000  +  0.000050i    cm-1
T2(ms=0)      0.000000  +  0.000282i    cm-1
T3(ms=0)      0.000000  +  -62.821197i    cm-1
T4(ms=0)      0.000000  +  0.001054i    cm-1
T5(ms=0)      0.000000  +  0.000013i    cm-1
SOC between the S5 state and excited triplet states (ms=1):
T1(ms=1)      (-18.542239)  + (0.000007i)    cm-1
T2(ms=1)      (0.000007)  + (0.000063i)    cm-1
T3(ms=1)      (0.000006)  + (-0.000434i)    cm-1
T4(ms=1)      (-0.000006)  + (-25.879056i)    cm-1
T5(ms=1)      (0.000003)  + (0.000089i)    cm-1
SOC between the S5 state and excited triplet states (ms=-1):
T1(ms=-1)    -(-18.542239)  + (0.000007i)    cm-1
T2(ms=-1)    -(0.000007)  + (0.000063i)    cm-1
T3(ms=-1)    -(0.000006)  + (-0.000434i)    cm-1
T4(ms=-1)    -(-0.000006)  + (-25.879056i)    cm-1
T5(ms=-1)    -(0.000003)  + (0.000089i)    cm-1
Total SOC between the S5 state and excited triplet states:
T1      26.222686    cm-1
T2      0.000296    cm-1
T3      62.821197    cm-1
T4      36.598512    cm-1
T5      0.000126    cm-1
            *********SOC CODE ENDS HERE*********
                    STATE-TO-STATE TRANSITION MOMENTS
    Electron Dipole Moments of Ground State
   State     X           Y           Z(a.u.)
       0    -0.000000    0.000000   -0.000000
 Within CIS/TDA Excited States:
    Electron Dipole Moments of Triplet Excited State
   State     X           Y           Z(a.u.)
       1    -0.000000    0.000000   -0.000000
       2    -0.000000    0.000000   -0.000000
       3    -0.000000   -0.000000   -0.000000
       4    -0.000000   -0.000000   -0.000000
       5    -0.000000   -0.000000   -0.000000
                Transition Moments Between Ground and Triplet Excited States
    States   X          Y          Z           Strength(a.u.)
    0    1   0.000000   0.000000   0.000000              0
    0    2   0.000000   0.000000   0.000000              0
    0    3   0.000000   0.000000   0.000000              0
    0    4   0.000000   0.000000   0.000000              0
    0    5   0.000000   0.000000   0.000000              0
                Transition Moments Between Triplet Excited States
    1    2  -0.000000  -0.000000  -0.000000   6.494388E-40
    1    3   0.000000   0.000000  -0.000000    1.10427E-38
    1    4  -0.000000  -0.000000   0.000000    7.99723E-39
    1    5   0.000000  -0.000000  -0.000000   1.467804E-39
    2    3   0.000000   0.000000   0.000000   9.336752E-39
    2    4  -0.000000  -0.000000  -0.000000   1.075217E-39
    2    5   0.000000  -0.000000   0.000000   3.514127E-40
    3    4  -0.000000   0.000000  -0.000000   6.911698E-40
    3    5   0.000000   0.000000   0.000000   4.094268E-41
    4    5   0.000000   0.000000   0.000000   1.029034E-40
    Electron Dipole Moments of Singlet Excited State
   State     X           Y           Z(a.u.)
       6     0.000000    0.000000   -0.000000
       7     0.000000    0.000000   -0.000000
       8    -0.000000    0.000000   -0.000000
       9     0.000000    0.000000   -0.000000
      10     0.000000    0.000000   -0.000000
                Transition Moments Between Ground and Singlet Excited States
    0    6  -0.000000  -0.000000   0.000000   5.094332E-31
    0    7   0.000000  -0.000000   0.000000   7.969081E-30
    0    8   0.000000   0.000000   0.000000   1.876901E-30
    0    9   0.000000   0.000000  -0.000000   6.654994E-30
    0   10   0.000000  -0.000000   0.000000   9.193339E-31
                Transition Moments Between Singlet Excited States
    6    7   0.000000   0.000000   0.000000   4.688525E-41
    6    8  -0.000000   0.000000   0.000000   4.849869E-41
    6    9   0.000000  -0.000000  -0.000000   3.004411E-40
    6   10  -0.000000  -0.000000   0.000000    1.64474E-40
    7    8   0.000000   0.000000  -0.000000   2.337829E-40
    7    9  -0.000000   0.000000  -0.000000   4.067484E-40
    7   10   0.000000   0.000000   0.000000   3.948606E-40
    8    9   0.000000  -0.000000   0.000000   2.348509E-40
    8   10   0.000000  -0.000000  -0.000000   1.870286E-40
    9   10  -0.000000  -0.000000  -0.000000   3.826249E-43
                    END OF TRANSITION MOMENT CALCULATION
 STSman time:  CPU 0.01 s  wall 0.01 s
                    Orbital Energies (a.u.)
 Alpha MOs
 -- Occupied --
******** -15.4574 -12.5920 -12.5920 -12.5920  -1.8342  -1.1075  -1.1075
 -1.1075  -0.1551
 -- Virtual --
 -0.0277  -0.0277  -0.0277  -0.0277  -0.0277  -0.0111  -0.0111  -0.0111
  0.0254   0.1680   0.1680   0.1680   0.1680   0.1680
          Ground-State Mulliken Net Atomic Charges
     Atom                 Charge (a.u.)
      1 Ca                   -0.000000
  Sum of atomic charges =     0.000000
                    Cartesian Multipole Moments
    Charge (ESU x 10^10)
                -0.0000
    Dipole Moment (Debye)
         X       0.0000      Y      -0.0000      Z       0.0000
       Tot       0.0000
        XX     -23.7775     XY       0.0000     YY     -23.7775
        XZ       0.0000     YZ       0.0000     ZZ     -23.7775
       XXX       0.0000    XXY      -0.0000    XYY       0.0000
       YYY      -0.0000    XXZ       0.0000    XYZ       0.0000
       YYZ       0.0000    XZZ       0.0000    YZZ      -0.0000
       ZZZ       0.0000
      XXXX     -85.6082   XXXY       0.0000   XXYY     -28.5361
      XYYY       0.0000   YYYY     -85.6082   XXXZ       0.0000
      XXYZ       0.0000   XYYZ       0.0000   YYYZ       0.0000
      XXZZ     -28.5361   XYZZ       0.0000   YYZZ     -28.5361
      XZZZ       0.0000   YZZZ       0.0000   ZZZZ     -85.6082
 STANDARD THERMODYNAMIC QUANTITIES AT   298.15 K  AND     1.00 ATM
   Translational Enthalpy:        0.889 kcal/mol
   Rotational Enthalpy:           0.000 kcal/mol
   Vibrational Enthalpy:          0.000 kcal/mol
   gas constant (RT):             0.592 kcal/mol
   Translational Entropy:        36.984  cal/mol.K
   Rotational Entropy:            0.000  cal/mol.K
   Vibrational Entropy:           0.000  cal/mol.K
   Total Enthalpy:                1.481 kcal/mol
   Total Entropy:                36.984  cal/mol.K
After diagonalising the full SOC matrix QCHEM gave me, this is what I’ve obtained:
              Relativistic states list
Number    Label     Energy (Ha)     Energy (cm-1)
0         E0        0.00000e+00     0.0000
1         E1        6.51318e-02     14294.7851
2         E2        6.51331e-02     14295.0705
3         E3        6.51357e-02     14295.6412
4         E4        6.54081e-02     14355.4093
5         E5        6.54139e-02     14356.6914
6         E6        6.54139e-02     14356.6964
7         E7        6.54146e-02     14356.8542
8         E8        6.54146e-02     14356.8542
9         E9        6.58251e-02     14446.9322
10        E10       6.58257e-02     14447.0634
11        E11       6.58284e-02     14447.6556
12        E12       6.58304e-02     14448.1132
13        E13       6.58310e-02     14448.2433
14        E14       6.58310e-02     14448.2433
15        E15       6.58310e-02     14448.2433
16        E16       8.42507e-02     18490.8840
17        E17       8.42507e-02     18490.8979
18        E18       8.42507e-02     18490.8984
19        E19       8.42508e-02     18490.9198
20        E20       8.42509e-02     18490.9269
Now compare to the values available on the NIST website which are the following:
Configuration  Term  J   Level  (cm-1)  Uncertainty (cm-1)   Reference
3p64s2  	 1S  	 0  	  0.000          	   	 L7185
3p64s4p  	 3P°  	 0  	  15 157.901          	   	 L7185
  	              	 1  	  15 210.063          	   	 L7185
     	  	         2  	  15 315.943          	   	 L7185
3p63d4s  	 3D  	 1  	  20 335.360          	   	 L7185
  	            	 2  	  20 349.260          	   	 L7185
            	  	 3  	  20 371.000          	   	 L7185
3p63d4s  	 1D  	 2  	  21 849.634          	   	 L7185
3p64s4p  	 1P°  	 1  	  23 652.304          	   	 L7185
3p64s5s  	 3S  	 1  	  31 539.495          	   	 L7185
3p64s5s  	 1S  	 0  	  33 317.264          	   	 L7185
3p63d4p  	 3F°  	 2  	  35 730.454          	   	 L7185
  	             	 3  	  35 818.713          	   	 L7185
  	            	 4  	  35 896.889          	   	 L7185
3p63d4p  	 1D°  	 2  	  35 835.413          	   	 L7185
Source: NIST ASD Levels Output
As you can see, there is quite a big difference between the two sets of results. If we take a look at the difference between the J=0 and J=2 states of the P triplet, we have for the NIST results a value of 158.042 cm-1 whereas QCHEM gives us less than 2 cm-1.
Now this isn’t a strike against QCHEM, as ORCA gave us similar results for the same method. We just want to understand why that is and how confident we can be in those results.
Thank you very much for your help!
Best regards!
Iacobellis Nicolas, Ph.D. Student
Hello Iacobellis,
Thank you for the information. The default of TDDFT SOC only includes one-electron operator. The numbers obtained from both one-electron and two-electron operators (ORCA) are roughly 0.6 smaller than the numbers obtained from Q-Chem 5.4. However, we have added two-electron operator (mean field) in Q-Chem 6.0. Acoording to the internal testing, the numbers using Q-Chem 6.0 beta agrees with the numbers obtained from ORCA. We would encrouage you to run the calculation again after Q-Chem 6.0 is released.
Edit: to the best of my knowledge, the SOC have been used to predict the phosphorescence rates. It’s unclear to me if they can be interpreted in terms of atomic spectra.
Thank you for your answer. ORCA and Q-CHEM already gave me close results so that wasn’t my main concern but glad to hear that Q-CHEM wil get even better!
I also asked this question on the ORCA forums and someone gave me this answer:
The first problem is you are not comparing the experimental results properly with the Orca calculations.
A 3P0 term is undegenerated (2J+1=1), while the 3P1 is triple degenerated (2J+1=3) and finally a 3P2 is 5th degenerated (2J+1=5). (…)
Being the ≈160cm-1 the difference between 1 and 5-9 and not the diference on the triplet.
Secondly, for the previous point, you can check your TDDFT electronic structure is very bad, because you are not obtaining the first 3P0 state, your states are the GS, an (2S+1)L1 and a (2S+1)L2 beeing miss the first (2S+1)L0.
What I don’t understand is why some states would be “missed” during calculation, especially the lower ones?
Thank you for your help,
Best regards,
The first thing to figure out is to make sure you look at the correct states. I recommend using NTOs for assigning state characters. State ordering can differ for different functionals, and this will obviously affect the results. Second, you should be aware about different algorithms for computing SOC in TDDFT. Third, I would first do EOM calculations for the reference and then set up DFT calculations in the same basis, to see if you could get the same states and then compare the resulting SOCs.
You may find this paper useful:
https://iopenshell.usc.edu/pubs/pdf/jcp-157-224110.pdf
