User-defined basis
As a sanity check before modifying basis sets, I’m trying to reproduce STO-6G as a user-defined basis set for the H2 singlet molecule.
--  An alpha spin H atom
0 2
H1
--  Another alpha spin H atom. Bonded ALMO-EDA does not need the multiplicities to sum to that of the molecule
0 -2
H2 H1 0.741
$ rem
JOBTYPE sp
BASIS gen
EXCHANGE scan
CORRELATION scan
PURECART 1
$ end
H  0
S  2  1.00
35.52322122 0.33687224
6.51314372 0.50844772
1.8221429 0.66780624
0.62595527 0.65884661
0.24307675 0.36427449
0.10011243 0.05860559
However, I am getting the following error:
    1      H       0.0000000000     0.0000000000    -0.3705000000
    2      H       0.0000000000     0.0000000000     0.3705000000
 Molecular Point Group                 D*h   NOp =***
 Largest Abelian Subgroup              D2h   NOp =  1
 Nuclear Repulsion Energy =           0.71413929 hartrees
 There are        1 alpha and        1 beta electrons
 Line found: 1.8221429 0.66780624
 The input format expected here:
  <character>   <integer>   <real optional>
  Or ****
 Q-Chem fatal error occurred in module forms1/Shell.C, line 376:
 Shell::FormatHelp : Case not known
What do I need to change? How do I interpret the scaling and K?
Please correct the $basis input.
H 0
S 6 1.00
will work but not
H 0
S 2 1.00
This modification allowed the calculation to run without any errors. After correcting an error in the basis definition, I also have energy equal to the pre-defined basis. Thanks, Kaushik!
