Using FRAGMO with ptSS-PCM and CDFT for Vertical Electron Transfer Calculation
Hi everyone,I am performing a vertical electron transfer calculation using SS-PCM (rf_ptss_save/read) in a two-step procedure:
  1. First job: TDDFT (CAM-B3LYP) single-point calculation with CPCM, saving the non-equilibrium solvent polarization using
    rf_ptss_save = true.
  2. Second job: Product-state single-point calculation using CDFT (with charge constraints), where I read the solvent polarization using
    rf_ptss_read = true and SCF_GUESS = READ.
    With the current approach, I am able to obtain results. However, I would like to set up the second step using the FRAGMO method instead of CDFT, because in the CDFT calculation I observe self-interaction contributions that may be affecting the energetics. But with FRAGMO method I am getting error. Can someone help me with this? I am sharing my input file:
    H -2.3947597 -2.6409220 -0.2454001
    C -3.0518069 -1.7876196 -0.1277040
    C -2.5125863 -0.4667684 -0.1623793
    C -3.4659280 0.5866937 -0.0228681
    H -3.1378048 1.6191429 -0.0553140
    C -4.8162386 0.3352052 0.1475658
    H -5.4984939 1.1751432 0.2496615
    C -5.3112673 -0.9697263 0.1886599
    H -6.3705717 -1.1609066 0.3223051
    C -4.4032394 -2.0228000 0.0428483
    H -4.7605915 -3.0491406 0.0605752
    C -1.1053100 -0.2148207 -0.2990558
    C -0.5567698 1.1104637 -0.3888651
    C 0.7860462 1.3486905 -0.4907584
    C 1.7545655 0.2955413 -0.5189614
    C 1.2112801 -1.0264213 -0.4933254
    C -0.1296088 -1.2684151 -0.3778886
    C 3.1795211 0.5520356 -0.6221959
    C 3.7294912 1.8318580 -0.3632027
    C 5.0893338 2.0753459 -0.4635083
    C 5.9749575 1.0595061 -0.8232920
    C 5.4595600 -0.2102991 -1.0825247
    C 4.1004707 -0.4610785 -0.9865479
    H -1.2215805 1.9668608 -0.3977569
    H 1.1162003 2.3785291 -0.5786257
    H 1.8812596 -1.8793355 -0.5183401
    H -0.4526656 -2.3026609 -0.3423568
    H 3.0794702 2.6419450 -0.0522110
    H 5.4662808 3.0716106 -0.2494934
    H 7.0398354 1.2526379 -0.8999823
    H 6.1274663 -1.0166352 -1.3726637
    H 3.7401883 -1.4559559 -1.2228686
    N -0.5493130 -0.1222658 2.7468223
    C 0.8886422 -0.1638791 2.7153696
    C 1.5679838 0.5397708 3.8926644
    C -1.2936050 -1.3517403 2.9464583
    C -1.0600668 -1.9865012 4.3205058
    C -1.2451067 1.1436980 2.8729565
    C -1.7697236 1.4268815 4.2829139
    H 1.2162543 0.3025379 1.7719636
    H 1.1884373 -1.2109927 2.6697941
    H 1.3265395 1.6039954 3.9253812
    H 2.6490548 0.4443409 3.7727555
    H 1.2827434 0.0846894 4.8435882
    H -0.9864791 -2.0489919 2.1634966
    H -2.3500338 -1.1294744 2.7960813
    H -0.0076690 -2.2375020 4.4696957
    H -1.6390550 -2.9106524 4.3777440
    H -1.3806515 -1.3285182 5.1297210
    H -2.0887181 1.1132129 2.1758088
    H -0.5662601 1.9305654 2.5446317
    H -2.5062600 0.6828014 4.5932736
    H -2.2605376 2.4025735 4.2764386
    H -0.9624457 1.4507261 5.0172042
    JOB_TYPE = SP
    METHOD = CAMB3LYP
    BASIS = 6-31G(d,p)
    DFT_D = D3
    CIS_N_ROOTS = 3
    CIS_SINGLETS = TRUE
    CIS_TRIPLETS = FALSE
    RPA = TRUE
    CIS_STATE_DERIV = 1
    SOLVENT_METHOD = PCM
theory iefpcm
rf_ptss_save true
Dielectric 37.5
OpticalDielectric 1.8068
– OPP
-1 2
– TEA
1 2
BASIS = 6-31G(d,p)
JOB_TYPE = SP
METHOD = CAMB3LYP
SCF_GUESS = FRAGMO
SCF_PRINT_FRGM = TRUE
DFT_D = D3
MEM_TOTAL = 248000
MEM_STATIC = 4000
theory iefpcm
rf_ptss_read true
Dielectric 37.5
What is the error? And if possible, please prepare a small-molecule example that’s easier for testing (i.e., same $rem etc. but different molecule).
The first job ran successfully. I got the error for the second job while it was handling the 1st fragment. The error message looks something like this:
Q-Chem fatal error occurred in module libmdc/newfileman.C, line 348:
FileMan error: End of file reached prematurely reading (16488) bytes in file UNKNOWN FILE
Path: /scratch1/hsaha/scratch/qchem/qchem577026//Frg1/8878.0
Q-Chem fatal error occurred in module gesman/frgmchild.C, line 693:
Error executing Q-Chem for fragment 1
Error in Q-Chem run part 2
remove work dirs /scratch1/hsaha/scratch/qchem/qchem577026.0 – /scratch1/hsaha/scratch/qchem/qchem577026.0
rm -rf /scratch1/hsaha/scratch/qchem/qchem577026.0
Error in the Q-Chem run
I’m not sure that this is available. The file number that’s triggering the problem is designed for transferring the electrostatic potential from the first job to the second, but then the 2nd job starts with a fragment calculation that differently sized.
