Is there a possibility to use molecular orbitals from pyscf as input to a QChem calculation?
Cheers,
Michael
Cheers,
Michael
Yes, this can be done by using the py2qchem module in open-source code MOKIT. For example, let’s perform a simple RHF calculation using PySCF,
from pyscf import gto, scf
from py2qchem import py2qchem
mol = gto.M(atom='''
O -0.49390246 0.93902438 0.0
H 0.46609754 0.93902438 0.0
H -0.81435705 1.84396021 0.0
basis='cc-pVDZ')
mf = scf.RHF(mol).run()
py2qchem(mf, 'h2o.in')
Then a Q-Chem input file h2o.in and a directory h2o will be generated. The MOs are held in the directory h2o/. (If the environment variables QCSCRATCH has been defined in your node/computer, the directory h2o will be automatically moved into $QCSCRATCH/; otherwise this directory will be put in the current directory.)
Now you can run
qchem h2o.in h2o.out h2o
you will see RHF in Q-Chem converges within 2 cycles and the energy cannot be lowered.
