vdW-TS (MBDVDW) vibrational frequencies
Hi John,
So I tested the calculation of the second derivative using HF and HF-MBD to see if MBD was taking into account using this two inputs:
Al           0.00000000000000        0.00000000000000        0.00000000000000
O            1.80185960291498       -0.00000982662585       -0.22421140724593
H            2.51639802970329        0.87356529080086       -0.12246105621416
H            2.51638889484236       -0.87359208188566       -0.12245800808720
JOBTYPE            FREQ
METHOD             HF
VIBMAN_PRINT       6
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
MBDVDW             MBD_SP
MBDVDW_BETA        10000
BASIS              Aug-cc-pvtz
SCF_CONVERGENCE    10
THRESH             14
` and this one:
JOBTYPE            FREQ
METHOD             HF
VIBMAN_PRINT       6
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
BASIS              Aug-cc-pvtz
SCF_CONVERGENCE    10
THRESH             14
But the results that I obtained were exactly the same. So I am not sure if the MBD contribution is being considerate. Do you know if there is a way of putting the mbd contribution on the second derivative?
Thanks in advance.
The bug that you’ve discovered is that MBD frequencies aren’t supported. The code should have told you this, and defaulted to finite difference, but it didn’t. I will submit a ticket.
If I set IDERIV=0 (with JOBTYPE=FREQ) to force, could be a way out?
I checked, and both IDERIV=0 and IDERIV=1 give the same result. There are two issues, which are that (1) the code should automatically go to finite-diff, and (2) apparently the MBD energy and gradient info aren’t added to the quantities that are differenced in the finite-diff code.
I think I manage to make it
For only HF:
 Mode:                 1                      2                      3
 Frequency:       615.69                1131.43                1148.05
 Force Cnst:      2.3597                 0.9368                 0.8742
 Red. Mass:      10.5656                 1.2420                 1.1257
 IR Active:          YES                    YES                    YES
 Raman Active:       YES                    YES                    YES
               X      Y      Z        X      Y      Z        X      Y      Z
 Al        -0.392  0.000  0.048    0.011 -0.000  0.020   -0.000 -0.030 -0.000
 O          0.600 -0.000 -0.089   -0.010  0.000 -0.121    0.000  0.079  0.000
 H          0.484 -0.012  0.058   -0.065 -0.029  0.698    0.656 -0.222 -0.130
 H          0.484  0.012  0.058   -0.065  0.029  0.698   -0.656 -0.222  0.130
 TransDip   0.000  0.000  0.000    0.000  0.000  0.000    0.000  0.000  0.000
 Mode:                 4                      5                      6
 Frequency:      1715.93                1877.28                1973.65
 Force Cnst:      1.8856                 2.3453                 2.3448
 Red. Mass:       1.0869                 1.1295                 1.0217
               X      Y      Z        X      Y      Z        X      Y      Z
 Al        -0.005  0.000 -0.001    0.000  0.007 -0.000    0.002  0.000 -0.000
 O         -0.072  0.000 -0.003   -0.000 -0.090  0.000    0.030 -0.000  0.006
 H          0.641 -0.292  0.037    0.319  0.620  0.096   -0.268 -0.653 -0.041
 H          0.641  0.292  0.037   -0.319  0.620 -0.096   -0.268  0.653 -0.041
For HF+MBD:
 Mode:                 1                      2                      3
 Frequency:       615.73                1131.52                1148.24
 Force Cnst:      2.3609                 0.9369                 0.8745
 Red. Mass:      10.5695                 1.2420                 1.1257
               X      Y      Z        X      Y      Z        X      Y      Z
 Al        -0.392  0.000  0.048    0.011 -0.000  0.020    0.000  0.030  0.000
 O          0.600 -0.000 -0.089   -0.010  0.000 -0.121   -0.000 -0.079 -0.000
 H          0.484 -0.012  0.058   -0.065 -0.029  0.698   -0.656  0.222  0.130
 H          0.484  0.012  0.058   -0.065  0.029  0.698    0.656  0.222 -0.130
 Mode:                 4                      5                      6
 Frequency:      1715.97                1877.09                1973.45
 Force Cnst:      1.8857                 2.3448                 2.3443
               X      Y      Z        X      Y      Z        X      Y      Z
 Al        -0.005  0.000 -0.001    0.000  0.007  0.000    0.002  0.000 -0.000
They are slightly different, so maybe it worked. So I basically used:
JOBTYPE            FREQ
IDERIV             0
METHOD             HF
VIBMAN_PRINT       6
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
BASIS              Aug-cc-pvtz
SCF_CONVERGENCE    10
THRESH             14
and:
JOBTYPE            FREQ
METHOD             HF
IDERIV             0
VIBMAN_PRINT       6
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
MBDVDW             MBD_SP
MBDVDW_BETA        10000
BASIS              Aug-cc-pvtz
SCF_CONVERGENCE    10
THRESH             14
My question is, if I want to see than the MBD contribution to the force constant, is it correct if I just subtract the HF-MBD force constant - HF force constant?
Those differences (sub-wavenumber) are in the convergence noise, I think. I don’t believe it’s possible to compute MBD frequencies with any current version of Q-Chem.
Hi John, So I was doing some tests and tried to obtain the gradients itself for the MBD (I ran an HF-MBD and PBE0-MBD) with this two inputs:
Al   0.00500000000000   0.00000000000000   0.00000000000000
JOBTYPE            force
METHOD             HF
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
BASIS              aug-cc-pVTZ
MBDVDW             MBD_FORCES
MBDVDW_BETA        10000
SCF_CONVERGENCE    10
THRESH             14
JOBTYPE            force
METHOD             PBE0
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
BASIS              aug-cc-pVTZ
MBDVDW             MBD_FORCES
MBDVDW_BETA        8500
SCF_CONVERGENCE    10
THRESH             14
But for both outputs I got the same error on the freq calculation for the MBD gradients:
 Energy from LibMBD: -6.767440482398079E-004
 Force calculation requested from LibMBD, resulting forces in a.u.
 Atom            1  :                      NaN                     NaN
                     NaN
 Atom            2  :                      NaN                     NaN
                     NaN
 Atom            3  :                      NaN                     NaN
                     NaN
 Atom            4  :                      NaN                     NaN
                     NaN
But I used to calculate the gradients for MBD all the time with Qchem 6.2.2 (see output ex below):
 Atom            1  :   5.131402789079820E-006  1.342466005685693E-005
 -3.325264617820776E-005
 Atom            2  :  -1.138175572790299E-005  2.207709259368315E-005
 -2.893676216140745E-005
 Atom            3  :   1.926679125458893E-005  1.492121304558350E-005
 -3.344003762037749E-005
 Atom            4  :  -1.135398386864196E-005 -8.084185932355496E-006
 -4.021526120510593E-005
 Atom            5  :  -8.099570615636543E-007 -2.960170487256917E-005
  9.394213031909857E-005
 Atom            6  :  -1.780055515351012E-006  2.218217141953931E-005
 -7.213803477315047E-005
 Atom            7  :  -2.436613481808033E-005 -1.664334197878195E-005
  3.710773661039494E-005
 Atom            8  :   1.728280549705957E-005 -2.929746094132065E-005
  3.293562194378651E-005
 Atom            9  :   8.010887450811649E-006  1.102155660936424E-005
  4.399725306496917E-005
| END Calculate MBD vdW contributions      |
Do you think it might be something with the new version? or my input is wrong?
No, there was a bug introduced in the MBD gradient at some point, it was noted also here:
and I opened a ticket already. I think something got broken in work with Tkatchenko’s group to add new libMBD features to Q-Chem but I’m not sure exactly.
I see, but does this bug appeared recently? because I was calculating 1 week ago with 6.2 the gradients. So I don’t know when it appeared or if its broken also on the older versions.
I noticed in March, in the run-up to the 6.3 release. You can check the veracity of the gradient by setting IDERIV=0 to get the finite-diff version.
Okay, I will try again with the 6.2.2 version and compare with the finite-diff than.
Thanks a lot for the help. I hope it fix this MBD bug soon.
Best.
Sorry, above message has been corrected to say IDERIV=0 (with JOBTYPE=FORCE). That will force a finite-diff evaluation of the gradient.
Hi John, I tested the MBD forces on both methods (with and without finite-diff) with the old version of qchem (6.2) and they gave me similar results. Than I tested again the FREQ calculation with finite-diff to see if something changed now that the MBD forces are computed. So I compared again the single HF with the HF-MBD with these two inputs:
JOBTYPE            FREQ
IDERIV             0
METHOD             HF
VIBMAN_PRINT       6
NO_REORIENT        TRUE
MAX_SCF_CYCLES     100
BASIS              Aug-cc-pvtz
SCF_CONVERGENCE    10
THRESH             14
JOBTYPE            FORCE
METHOD             HF
NO_REORIENT        TRUE
MBDVDW             MBD_FORCES
MBDVDW_BETA        10000
MAX_SCF_CYCLES     100
BASIS              Aug-cc-pvtz
SCF_CONVERGENCE    10
THRESH             14
So this time I got some larger difference on the output:
Only HF:
 Vibrational Frequencies in atomic units
    -0.0000000000   -0.0000000000    0.0000000000    0.0000000000    0.0000000000    0.0000000000
     0.0143452775    0.0484443606    0.0498777267    0.1114262341    0.1333656444    0.1474101892
 Vibrational Electric Transition dipole:  1      0.00000000000000    0.00000000000000    0.00000000000000
 Vibrational Electric Transition dipole:  2      0.00000000000000    0.00000000000000    0.00000000000000
 Vibrational Electric Transition dipole:  3      0.00000000000000    0.00000000000000    0.00000000000000
 Vibrational Electric Transition dipole:  4      0.00000000000000    0.00000000000000    0.00000000000000
 Vibrational Electric Transition dipole:  5      0.00000000000000    0.00000000000000    0.00000000000000
 Vibrational Electric Transition dipole:  6      0.00000000000000    0.00000000000000    0.00000000000000
 **                       VIBRATIONAL ANALYSIS                       **
 **        VIBRATIONAL FREQUENCIES (CM**-1) AND NORMAL MODES         **
 **     FORCE CONSTANTS (mDYN/ANGSTROM) AND REDUCED MASSES (AMU)     **
 Mode:                 1                      2                      3
 Force Cnst:      2.3597                 0.9367                 0.8742
 Red. Mass:      10.5655                 1.2420                 1.1257
               X      Y      Z        X      Y      Z        X      Y      Z
 Mode:                 4                      5                      6
 Frequency:      1715.93                1877.27                1973.65
               X      Y      Z        X      Y      Z        X      Y      Z
 STANDARD THERMODYNAMIC QUANTITIES AT   298.15 K  AND     1.00 ATM
HF-MBD:
    -0.0095308677   -0.0000000000   -0.0000000000   -0.0000000000    0.0000000000    0.0000000000
     0.0000000000    0.0186908969    0.0395645335    0.1480780125    0.1967981655    0.2851517078
 Mode:                 1                      2                      3
 Frequency:      -501.85                 702.78                1022.49
 Force Cnst:      0.1769                 4.4866                 0.7318
 Red. Mass:       1.1923                15.4180                 1.1880
               X      Y      Z        X      Y      Z        X      Y      Z
 Al        -0.016 -0.021 -0.013   -0.456 -0.007  0.062   -0.025  0.024 -0.010
 O         -0.002  0.066  0.081    0.760  0.016 -0.127    0.016 -0.072  0.066
 H          0.619 -0.303 -0.568    0.246  0.138  0.152   -0.240  0.153 -0.288
 H         -0.160 -0.172 -0.368   -0.109 -0.191  0.207    0.668  0.344 -0.510
 Mode:                 4                      5                      6
 Frequency:      1978.11                2280.43                2745.01
 Force Cnst:      2.3635                 3.3007                 4.8087
 Red. Mass:       1.0252                 1.0773                 1.0832
               X      Y      Z        X      Y      Z        X      Y      Z
 Al        -0.008 -0.001  0.005   -0.004  0.001  0.001   -0.019 -0.001  0.007
 O         -0.005 -0.014 -0.028   -0.024 -0.063 -0.008   -0.041  0.031 -0.041
 H          0.278 -0.525  0.166    0.614  0.735  0.113    0.399 -0.120  0.203
 H          0.020  0.773  0.144   -0.113  0.231 -0.007    0.762 -0.363  0.263
Do you think now it can being computed the MBD contribution to the total force constants?
I’ve looked into this some more, and I now think the vdW-TS energy does get added into the total SCF energy, so finite-diff with IDERIV=0 should give correct frequencies. If those agree with IDERIV=1 (which it seems to do in my tests), then those are also correct frequencies. I’ve noticed that the finite-diff procedure is a bit unusually sensitive to thresholds and I suspect that has to do with computing the Hirshfeld volumes that are needed for the dispersion correction. The analytic 2nd derivatives are definitely not implemented and that should get backstopped but does not. (I will add for next release.)
Note: I made this a new topic because the discussion has strayed pretty far from your original question about DC-DFT.
Thanks a lot for all the clarifications.
So just for the record and future reference, the bug here is a user request for frequencies with vdW-TS doesn’t automatically go to finite difference. I will put in a fix for that for the Q-Chem 7 release.
