I want to run a cc2 calculation . And how better to set $rem to calculate lager molecules , as I have used ri cc2 so far.
If there are some errors in my input file.
Is there a specific error that you are getting? If so, please paste the full input file using a preformatted text box (button that looks like </>), and similarly post the error message that you are getting.
METHOD cc2
BASIS cc-pvdz
AUX_BASIS rimp2-cc-pvdz
MEM_TOTAL = 250000
cc_memory = 248000
THREADS 28
EE_SINGLETS = 1
EE_TRIPLETS = 1
IQMOL_FCHK = TRUE
NTO_PAIRS = 2
STATE_ANALYSIS = true
POP_MULLIKEN = true
Q-Chem fatal error occurred in module /scratch/qcdevops/jenkins/workspace/build_qchem_linux_distrib/tags/qc602/qchem/ccman2/qchem/ccman2_main.C, line 26:
Key 't' is not known.
Many thanks.
I can reproduce this with simple example of H2 molecule, and it seem to be related to STATE_ANALYSIS (because without that, the job runs to completion). Please contact Q-Chem support.
Thanks John. I have one more question ,how to get NTO, i set molden_format true ,but did not get the molden.
METHOD eom-ccsd
BASIS cc-pvdz
MEM_TOTAL = 250000
cc_memory = 248000
THREADS 28
EE_SINGLETS = 1
EE_TRIPLETS = 1
IQMOL_FCHK = TRUE
NTO_PAIRS = 2
POP_MULLIKEN = true
cc_sp_t_conv = 4
cc_sp_e_conv = 6
cc_single_prec = 1
eom_single_prec = 1
cc_ref_prop = 1
CC_SP_DM = 1
cholesky_tol = 3
cc_trans_prop = 1
MOLDEN_FORMAT = TRUE
I think NTOs in Molden format may only work for CIS/TDDFT wave functions. The libwfa code can produce them for correlated wave functions; please check the manual.
Orbitals in molden format are available for EOM-CCSD jobs but you need to remove IQMOL_FCHK = TRUE from your $rem section.
Both IQMOL_FCHK = TRUE and GUI = 2 keywords are incompatible with MODEN_FORMAT = TRUE
If I run your job like this I get the molden file for NTOs in the plots folder.
Thank you very much.
would be nice if there were a run-time check for this incompatibility, in the input parser.
