I am interested in running RSCF, USCF, ROSCF, and ROKS calculations on large molecules. What of the different RI approximations (RI_J, RI_K, PARI_K, OCC_RI_K) are safe to use for these types of SCFs with QChem?
RI-J + occ-RI-K with large MEM_TOTAL is recommended when large basis set (higher than TZ) is used. You can test some systems to see if it works for you. RI-K and PARI-K is not recommended.
Roger on the requirements (TZ or beyond, large memory) to make RI useful. That aside, I am concerned about whether RI is implemented for ROSCF and ROKS calculations. For example, just as a test system and not expecting improvements in timing:
Plain old RSCF.
Fe
C 1 rFeC_Short
C 1 rFeC_Short 2 a_CC_Short
C 1 rFeC_Long 3 a_CC_LS 2 d_CL_Fe_CS_CS
C 1 rFeC_Long 2 a_CC_LS 3 d_CL_Fe_CS_CS
O 1 rFeO_Short 2 a_CO_Short 4 d_OS_Fe_CS_CL
O 1 rFeO_Short 3 a_CO_Short 5 d_OS_Fe_CS_CL
O 1 rFeO_Long 4 a_CO_Long 2 d_OL_Fe_CL_CS
O 1 rFeO_Long 5 a_CO_Long 3 d_OL_Fe_CL_CS
rFeC_Short = 1.78765
rFeO_Short = 2.92720
rFeC_Long = 1.84212
rFeO_Long = 2.97961
a_CC_Short = 122.24979
a_CC_Long = 164.91464
a_CC_LS = 93.63430
a_CO_Short = 119.08885
a_CO_Long = 163.37067
d_CL_Fe_CS_CS = 96.61375
d_OL_Fe_CL_CS = 118.66525
d_OS_Fe_CS_CL = 96.61375
METHOD WB97M-V
BASIS def2-SVP
AUX_BASIS RIJK-def2-SVP
RI_J TRUE
occ_RI_K TRUE
SYMMETRY FALSE
SYM_IGNORE TRUE
SCF_ALGORITHM GDM
MAX_SCF_CYCLES 200
MEM_STATIC 500
THRESH 14
ROSCF calculation on the triplet state.
Fe
C 1 rFeC_Short
rFeC_Long = 1.84212
rFeO_Long = 2.97961
a_CC_LS = 93.63430
UNRESTRICTED FALSE
METHOD WB97M-V
BASIS def2-SVP
RI_J TRUE
occ_RI_K TRUE
SYMMETRY FALSE
SYM_IGNORE TRUE
SCF_GUESS READ
SCF_ALGORITHM GDM
MAX_SCF_CYCLES 200
MEM_STATIC 500
THRESH 14
The energy differences between the RSCF and the ROSCF solution seem to be consistent with and without RI but I want to thread with caution, as there is no mention in the manual with regards to which types of SCF are supported for RI and the agreement could be fortuitous in this case.
Both calculations trigger RI-J + occ-RI-K. You can check if you can find out print out like βThe virtual molecular orbitals are not correct because of occ-RI-K.β in the output. Because the virtual orbitals computed by occ-RI-K is not correct, there should be related messages printed and the virtual orbital energies are missing in the output, when occ-RI-K is used for SCF.
