Can MEM_STATIC be set to more than 2 GB?
Dear all,
I am now working on geometry optimization of CaOCH3 with aug-cc-pwCVTZ-PP basis set and it is taking forever. When I checked the output file, it is always in the middle of the integral transformation. The output is always like this
Adding separable TPDM in double precision
Transferring MO TPDM to AO TPDM
Transferring g2_o1o1o1o1
Transferring g2_o1o1o1v1
Transferring g2_o1o1v1v1
Transferring g2_o1v1o1v1
Transferring g2_o1v1v1v1
Transferring g2_v1v1v1v1
I set MEM_STATIC to be more than 2000 MB but Qchem alwats automatically adusts it to be 2000 MB.
Is it possible to set it to more than 2000 MB and does it speed up the job?
(For MEM_TOTAL and CC_MEMORY, I set them to be 300 GB and 290 GB respectively, so those should be enough.)
Thank you very much in advance.
Hello Yuiki,
The limit of MEM_STATIC is due to fortran’s ALLOCATE calls in the code. For CC jobs, we recommend disabling CC_MEMORY, which is outdated, and letting the algorithm automatically determines the required memory. If you still run into the memory problem, you may post an output so we can help you resolve the issue.
Thank you very much for your suggestion. I disabled CC_MEMORY but it didn’t resolve the issue. Since it seems to run even slower than before, I just canceled the job. The input file is the following.
  optimization, CaOCH3
  O, C, H: aug-ccpvtz
  Ca: aug-ccpwcvtz-pp + ECP10MDF
  Ca
  O  1 1.929561
  C  2 1.418529 1 179.990254
  H  3 1.102702 2 110.427813 1 180.000000 0
  H  3 1.102702 2 110.428062 1 -60.000170 0
  H  3 1.102702 2 110.428062 1 60.000168 0
     BASIS  = GEN
     ECP = GEN
     PURECART = 11
     GUI  =  2
     JOB_TYPE  =  Optimization
     METHOD  =  EOM-CCSD
     EA_STATES = [1]
     CC_STATE_TO_OPT = [1,1]
     SCF_CONVERGENCE  = 8
     SCF_MAX_CYCLES = 1000
     MEM_TOTAL = 100000
     N_FROZEN_CORE = 0
     SYM_IGNORE = TRUE
     symmetry = false
     GEOM_OPT_TOL_GRADIENT = 10
     GEOM_OPT_TOL_DISPLACEMENT = 10
     GEOM_OPT_TOL_ENERGY = 10
  Ca     0
  S   11   1.00
        1.976220D+02           4.190000D-04
        1.792900D+01          -2.156500D-02
        1.119920D+01           1.633830D-01
        6.720690D+00          -2.170500D-01
        3.608020D+00          -3.102700D-01
        1.086620D+00           4.477000D-01
        5.675900D-01           5.787130D-01
        2.888920D-01           2.107180D-01
        9.042600D-02           6.936000D-03
        4.293500D-02          -2.056000D-03
        1.998100D-02           4.790000D-04
  S   11   1.00
        1.976220D+02          -1.130000D-04
        1.792900D+01           5.589000D-03
        1.119920D+01          -4.376500D-02
        6.720690D+00           6.133500D-02
        3.608020D+00           8.280200D-02
        1.086620D+00          -1.359780D-01
        5.675900D-01          -2.451600D-01
        2.888920D-01          -2.181830D-01
        9.042600D-02           3.448770D-01
        4.293500D-02           6.355140D-01
        1.998100D-02           2.211240D-01
  S   1   1.00
        1.424600D+00           1.000000D+00
  S   1   1.00
        6.682000D-01           1.000000D+00
  S   1   1.00
        9.042600D-02           1.000000D+00
  S   1   1.00
        4.293500D-02           1.000000D+00
  S   1   1.00
        1.998100D-02           1.000000D+00
  S   1   1.00
        9.300000D-03           1.000000D+00
  P   9   1.00
        1.768320D+02           1.470000D-04
        3.099220D+01           2.268000D-03
        7.596910D+00          -5.310800D-02
        1.534000D+00           3.211830D-01
        7.070850D-01           4.856770D-01
        3.241280D-01           2.798660D-01
        1.255100D-01           3.565400D-02
        5.354900D-02          -1.958000D-03
        2.208100D-02           9.840000D-04
  P   9   1.00
        1.768320D+02          -3.900000D-05
        3.099220D+01          -4.560000D-04
        7.596910D+00           1.185800D-02
        1.534000D+00          -8.120500D-02
        7.070850D-01          -1.211530D-01
        3.241280D-01          -1.113470D-01
        1.255100D-01           1.793740D-01
        5.354900D-02           6.081730D-01
        2.208100D-02           3.480400D-01
  P   1   1.00
        1.786300D+00           1.000000D+00
  P   1   1.00
        3.162000D-01           1.000000D+00
  P   1   1.00
        1.255100D-01           1.000000D+00
  P   1   1.00
        2.208100D-02           1.000000D+00
  P   1   1.00
        9.100000D-03           1.000000D+00
  D   6   1.00
        1.317760D+01           2.022800D-02
        3.803500D+00           9.116100D-02
        1.259800D+00           2.164420D-01
        4.132510D-01           3.283810D-01
        1.271630D-01           4.345680D-01
        3.826200D-02           3.598780D-01
  D   1   1.00
        3.944600D+00           1.000000D+00
  D   1   1.00
        1.252500D+00           1.000000D+00
  D   1   1.00
        1.271630D-01           1.000000D+00
  D   1   1.00
        3.826200D-02           1.000000D+00
  D   1   1.00
        1.530000D-02           1.000000D+00
  F   1   1.00
        6.043000D-01           1.000000D+00
  F   1   1.00
        1.368000D-01           1.000000D+00
  F   1   1.00
        5.470000D-02           1.000000D+00
  H     0
  S   5   1.00
        3.387000D+01           6.068000D-03
        5.095000D+00           4.530800D-02
        1.159000D+00           2.028220D-01
        3.258000D-01           5.039030D-01
        1.027000D-01           3.834210D-01
  S   1   1.00
        3.258000D-01           1.000000D+00
  S   1   1.00
        1.027000D-01           1.000000D+00
  S   1   1.00
        0.0252600              1.0000000
  P   1   1.00
        1.407000D+00           1.000000D+00
  P   1   1.00
        3.880000D-01           1.000000D+00
  P   1   1.00
        0.1020000              1.0000000
  D   1   1.00
        1.057000D+00           1.0000000
  D   1   1.00
        0.2470000              1.0000000
  C     0
  S   10   1.00
        8.236000D+03           5.310000D-04
        1.235000D+03           4.108000D-03
        2.808000D+02           2.108700D-02
        7.927000D+01           8.185300D-02
        2.559000D+01           2.348170D-01
        8.997000D+00           4.344010D-01
        3.319000D+00           3.461290D-01
        9.059000D-01           3.937800D-02
        3.643000D-01          -8.983000D-03
        1.285000D-01           2.385000D-03
  S   10   1.00
        8.236000D+03          -1.130000D-04
        1.235000D+03          -8.780000D-04
        2.808000D+02          -4.540000D-03
        7.927000D+01          -1.813300D-02
        2.559000D+01          -5.576000D-02
        8.997000D+00          -1.268950D-01
        3.319000D+00          -1.703520D-01
        9.059000D-01           1.403820D-01
        3.643000D-01           5.986840D-01
        1.285000D-01           3.953890D-01
  S   1   1.00
        9.059000D-01           1.000000D+00
  S   1   1.00
        1.285000D-01           1.000000D+00
  S   1   1.00
        0.0440200              1.0000000
  P   5   1.00
        1.871000D+01           1.403100D-02
        4.133000D+00           8.686600D-02
        1.200000D+00           2.902160D-01
        3.827000D-01           5.010080D-01
        1.209000D-01           3.434060D-01
  P   1   1.00
        3.827000D-01           1.000000D+00
  P   1   1.00
        1.209000D-01           1.000000D+00
  P   1   1.00
        0.0356900              1.0000000
  D   1   1.00
        1.097000D+00           1.000000D+00
  D   1   1.00
        3.180000D-01           1.000000D+00
  D   1   1.00
        0.1000000              1.0000000
  F   1   1.00
        7.610000D-01           1.0000000
  F   1   1.00
        0.2680000              1.0000000
  O     0
  S   10   1.00
        1.533000D+04           5.080000D-04
        2.299000D+03           3.929000D-03
        5.224000D+02           2.024300D-02
        1.473000D+02           7.918100D-02
        4.755000D+01           2.306870D-01
        1.676000D+01           4.331180D-01
        6.207000D+00           3.502600D-01
        1.752000D+00           4.272800D-02
        6.882000D-01          -8.154000D-03
        2.384000D-01           2.381000D-03
  S   10   1.00
        1.533000D+04          -1.150000D-04
        2.299000D+03          -8.950000D-04
        5.224000D+02          -4.636000D-03
        1.473000D+02          -1.872400D-02
        4.755000D+01          -5.846300D-02
        1.676000D+01          -1.364630D-01
        6.207000D+00          -1.757400D-01
        1.752000D+00           1.609340D-01
        6.882000D-01           6.034180D-01
        2.384000D-01           3.787650D-01
  S   1   1.00
        1.752000D+00           1.000000D+00
  S   1   1.00
        2.384000D-01           1.000000D+00
  S   1   1.00
        0.0737600              1.0000000
  P   5   1.00
        3.446000D+01           1.592800D-02
        7.749000D+00           9.974000D-02
        2.280000D+00           3.104920D-01
        7.156000D-01           4.910260D-01
        2.140000D-01           3.363370D-01
  P   1   1.00
        7.156000D-01           1.000000D+00
  P   1   1.00
        2.140000D-01           1.000000D+00
  P   1   1.00
        0.0597400              1.0000000
  D   1   1.00
        2.314000D+00           1.000000D+00
  D   1   1.00
        6.450000D-01           1.000000D+00
  D   1   1.00
        0.2140000              1.0000000
  F   1   1.00
        1.428000D+00           1.0000000
  F   1   1.00
        0.5000000              1.0000000
  $ecp
  CA     0
  CA-ECP     4     10
  g potential
    1
  2      1.                     0.
  s-g potential
    2
  2     10.556058402          138.832728745
  2      5.293154907           16.754824599
  p-g potential
    4
  2     12.714571445           27.661607611
  2     12.878516057           55.297862576
  2      4.147923622            4.210974307
  2      3.841287457            7.627482586
  d-g potential
    4
  2      4.703264136           -0.514324716
  2      4.707975898           -0.765184799
  2     13.696151450           -6.490621584
  2     13.698165108           -9.735555558
  f-g potential
    2
  2     14.820019137          -14.000148237
  2     22.000803239          -61.616066332
The output file is the following. (I just cut some of the unrelated parts since the ouput file contents exceeded the words limit here)
   Q-Chem 5.3.2 for Intel X86 EM64T Linux
   Parts of Q-Chem use Armadillo 9.800.1 (Horizon Scraper).
   http://arma.sourceforge.net/
   Q-Chem begins on Tue Jun 22 06:14:26 2021
  Host:
  0
       Scratch files written to /central/scratch/hutzlerlab/qchem193887//
   Dec820 |scratch|qcdevops|jenkins|workspace|build_RNUM 7577
  Processing $rem in /central/groups/hutzlerlab/software/qchem/config/preferences:
  Processing $rem in /home/yuiki/.qchemrc:
  Requested ECP is GEN
  EOM-IP/EA analytic gradients are available only for UHF references
  Setting UNRESTRICTED=TRUE
  Checking the input file for inconsistencies... 	...done.
  User input:
  optimization, CaAuH
  Sb, P, N, Al, F. Cl, Br, S, O, C, H: aug-ccpvtz
  Ge, Sn, Ca. Au: aug-ccpwcvtz-pp + ECP10MDF
  Si: aug-ccpwcvtz
  Ca
  O  1 1.929561
  BASIS  = GEN
  ECP = GEN
  PURECART = 11
  GUI  =  2
  METHOD  =  EOM-CCSD
  EA_STATES = [1]
  SCF_CONVERGENCE  = 8
  MEM_TOTAL = 100000
  N_FROZEN_CORE = 0
  SYM_IGNORE = TRUE
  symmetry = false
      1      Ca      0.0000000000     0.0000000000     0.0000000000
      2      O       0.0000000000     0.0000000000     1.9295610000
      3      C       0.0002412915     0.0000000000     3.3480899795
      4      H      -1.0330492448     0.0000000000     3.7331385070
      5      H       0.5169812690    -0.8949126472     3.7328793379
      6      H       0.5169813002     0.8949126291     3.7328793379
   Nuclear Repulsion Energy =          69.06320319 hartrees
   There are       13 alpha and       13 beta electrons
   There are 79 shells and 241 basis functions
   Total memory of 100000 MB is distributed as follows:
     MEM_STATIC is set to 192 MB
     QALLOC/CCMAN JOB total memory use is  99808 MB
   Warning: actual memory use might exceed 100000 MB
   Total QAlloc Memory Limit 100000 MB
   Mega-Array Size       188 MB
   MEM_STATIC part       192 MB
   A cutoff of  1.0D-14 yielded   3142 shell pairs
   There are     29314 function pairs (     39691 Cartesian)
   Compound shells will be simplified
   Smallest overlap matrix eigenvalue = 5.03E-05
   Nucleus-field energy     =    -0.0000000147 hartrees
   Guess MOs from core Hamiltonian diagonalization
    Bang C. Huynh
   Hartree-Fock
   using 32 threads for integral computing
   A unrestricted SCF calculation will be
   performed using DIIS
    Cycle       Energy         DIIS error
      1    -121.5439837426      4.06e-02
      2    -123.6697200518      1.59e-02
      3    -136.0910420402      2.22e-02
      4    -147.2228529581      1.26e-02
      5    -149.5476932545      6.86e-03
      6    -150.5777389250      2.97e-03
      7    -150.8125826806      4.91e-04
      8    -150.8189350837      8.36e-05
      9    -150.8193809777      3.90e-05
     10    -150.8194230007      6.05e-06
     11    -150.8194256371      3.51e-06
     12    -150.8194260560      4.88e-07
     13    -150.8194260701      1.15e-07
     14    -150.8194260707      1.58e-08
     15    -150.8194260707      2.89e-09  Convergence criterion met
   SCF time:   CPU 562.78s  wall 18.00s
  <S^2> =          0.000000000
   SCF   energy in the final basis set =     -150.8194260707
   Total energy in the final basis set =     -150.8194260707
     CCMAN2: suite of methods based on coupled cluster
             and equation of motion theories.
     Components:
     * libvmm-1.3-trunk
       by Evgeny Epifanovsky, Ilya Kaliman.
     * libtensor-2.5-trunk
       by Evgeny Epifanovsky, Michael Wormit, Dmitry Zuev, Sam Manzer,
          Ilya Kaliman.
     * libcc-2.5-trunk
       by Evgeny Epifanovsky, Arik Landau, Tomasz Kus, Kirill Khistyaev,
          Dmitry Zuev, Prashant Manohar, Xintian Feng, Anna Krylov,
          Matthew Goldey, Alec White, Thomas Jagau, Kaushik Nanda,
          Anastasia Gunina, Alexander Kunitsa, Joonho Lee.
     CCMAN original authors:
     Anna I. Krylov, C. David Sherrill, Steven R. Gwaltney,
     Edward F. C. Byrd (2000)
     Sergey V. Levchenko, Lyudmila V. Slipchenko, Tao Wang,
     Ana-Maria C. Cristian (2003)
     Piotr A. Pieniazek, C. Melania Oana, Evgeny Epifanovsky (2007)
     Prashant Manohar (2009)
   Allocating and initializing 99808MB of RAM...
   Calculation will run on 32 cores.
   Alpha MOs, Unrestricted
   -- Occupied --
  -20.644 -11.372  -2.474  -1.548  -1.523  -1.523  -1.379  -0.998
    1 A     2 A     3 A     4 A     5 A     6 A     7 A     8 A
   -0.710  -0.710  -0.700  -0.546  -0.546
    9 A    10 A    11 A    12 A    13 A
   -- Virtual --
   -0.183  -0.117  -0.117  -0.101  -0.071  -0.071  -0.070  -0.054
   14 A    15 A    16 A    17 A    18 A    19 A    20 A    21 A
   -0.054  -0.048  -0.048  -0.048  -0.040  -0.029  -0.029  -0.011
   22 A    23 A    24 A    25 A    26 A    27 A    28 A    29 A
   -0.010  -0.010  -0.006  -0.003  -0.003  -0.002   0.030   0.030
   30 A    31 A    32 A    33 A    34 A    35 A    36 A    37 A
    0.042   0.046   0.046   0.061   0.062   0.062   0.065   0.065
   38 A    39 A    40 A    41 A    42 A    43 A    44 A    45 A
    0.066   0.066   0.088   0.088   0.092   0.103   0.119   0.119
   46 A    47 A    48 A    49 A    50 A    51 A    52 A    53 A
    0.163   0.163   0.171   0.192   0.197   0.197   0.215   0.248
   54 A    55 A    56 A    57 A    58 A    59 A    60 A    61 A
    0.248   0.257   0.264   0.289   0.294   0.294   0.317   0.317
   62 A    63 A    64 A    65 A    66 A    67 A    68 A    69 A
    0.322   0.332   0.334   0.334   0.386   0.386   0.410   0.417
   70 A    71 A    72 A    73 A    74 A    75 A    76 A    77 A
    0.417   0.418   0.418   0.435   0.435   0.475   0.475   0.476
   78 A    79 A    80 A    81 A    82 A    83 A    84 A    85 A
    0.496   0.496   0.506   0.555   0.587   0.587   0.607   0.607
   86 A    87 A    88 A    89 A    90 A    91 A    92 A    93 A
    0.676   0.722   0.722   0.737   0.739   0.798   0.805   0.805
   94 A    95 A    96 A    97 A    98 A    99 A   100 A   101 A
    0.861   0.861   0.867   0.930   0.930   0.949   0.967   0.967
  102 A   103 A   104 A   105 A   106 A   107 A   108 A   109 A
    0.980   1.014   1.053   1.053   1.098   1.098   1.135   1.135
  110 A   111 A   112 A   113 A   114 A   115 A   116 A   117 A
    1.171   1.193   1.193   1.245   1.317   1.385   1.386   1.386
  118 A   119 A   120 A   121 A   122 A   123 A   124 A   125 A
    1.479   1.479   1.501   1.523   1.523   1.590   1.590   1.592
  126 A   127 A   128 A   129 A   130 A   131 A   132 A   133 A
    1.613   1.623   1.623   1.745   1.773   1.809   1.809   1.820
  134 A   135 A   136 A   137 A   138 A   139 A   140 A   141 A
    1.822   1.844   1.849   1.849   1.909   1.909   1.953   1.953
  142 A   143 A   144 A   145 A   146 A   147 A   148 A   149 A
    2.013   2.076   2.076   2.135   2.169   2.203   2.203   2.286
  150 A   151 A   152 A   153 A   154 A   155 A   156 A   157 A
    2.308   2.308   2.372   2.423   2.423   2.560   2.652   2.652
  158 A   159 A   160 A   161 A   162 A   163 A   164 A   165 A
    2.657   2.731   2.731   3.008   3.106   3.107   3.157   3.263
  166 A   167 A   168 A   169 A   170 A   171 A   172 A   173 A
    3.263   3.417   3.457   3.497   3.497   3.629   3.629   3.767
  174 A   175 A   176 A   177 A   178 A   179 A   180 A   181 A
    3.767   3.833   3.912   3.912   3.969   4.074   4.074   4.121
  182 A   183 A   184 A   185 A   186 A   187 A   188 A   189 A
    4.188   4.188   4.220   4.413   4.413   4.443   4.649   4.649
  190 A   191 A   192 A   193 A   194 A   195 A   196 A   197 A
    4.671   4.671   4.777   4.835   4.905   4.924   4.924   5.178
  198 A   199 A   200 A   201 A   202 A   203 A   204 A   205 A
    5.263   5.264   5.264   5.446   5.464   5.464   5.567   5.851
  206 A   207 A   208 A   209 A   210 A   211 A   212 A   213 A
    5.957   5.957   6.167   6.505   6.505   6.522   6.524   6.799
  214 A   215 A   216 A   217 A   218 A   219 A   220 A   221 A
    6.799   7.122   7.122   7.159   7.159   7.274   7.274   7.381
  222 A   223 A   224 A   225 A   226 A   227 A   228 A   229 A
    7.381   7.403   7.675   7.675   7.904   8.095   8.251   8.251
  230 A   231 A   232 A   233 A   234 A   235 A   236 A   237 A
    9.728  13.435  17.346  37.564
  238 A   239 A   240 A   241 A
   Beta MOs, Unrestricted
   -- Occupied --
   -- Virtual --
   Occupation and symmetry of molecular orbitals
   Point group: C1 (1 irreducible representation).
                             A     All
   All molecular orbitals:
    - Alpha                  241   241
    - Beta                   241   241
   Alpha orbitals:
    - Frozen occupied        0     0
    - Active occupied        13    13
    - Active virtual         228   228
    - Frozen virtual         0     0
   Beta orbitals:
   Import integrals:   CPU 0.00 s  wall 0.00 s
   Import integrals:   CPU 9007.88 s  wall 297.78 s
   MP2 amplitudes:   CPU 2.41 s  wall 0.15 s
  Running a double precision version
             CCSD T amplitudes will be solved using DIIS.
             Start     Size      MaxIter   EConv     TConv
             3         7         100       1.00e-07  1.00e-05
             Energy (a.u.)   Ediff      Tdiff       Comment
            -151.54820901
       1    -151.55435377   6.14e-03   7.07e-01
       2    -151.57252333   1.82e-02   8.28e-02
       3    -151.57086998   1.65e-03   3.24e-02
       4    -151.57270238   1.83e-03   2.92e-02     Switched to DIIS steps.
       5    -151.57339074   6.88e-04   7.28e-03
       6    -151.57345407   6.33e-05   2.25e-03
       7    -151.57345034   3.73e-06   1.01e-03
       8    -151.57344856   1.78e-06   5.14e-04
       9    -151.57345002   1.46e-06   1.46e-04
      10    -151.57344980   2.23e-07   6.01e-05
      11    -151.57345066   8.63e-07   3.29e-05
      12    -151.57345057   9.15e-08   9.57e-06
            -151.57345057                           CCSD T converged.
  End of double precision
   SCF energy                 = -150.81942607
   MP2 energy                 = -151.54820901
   CCSD correlation energy    =   -0.75402450
   CCSD total energy          = -151.57345057
   CCSD  T1^2 = 0.0090  T2^2 = 0.2039  Leading amplitudes:
   Amplitude    Orbitals with energies
   -0.0222       13 (A) B                  ->    31 (A) B
                -0.5456                         -0.0102
   -0.0222       13 (A) A                  ->    31 (A) A
                -0.5456                         -0.0102
   -0.0222       12 (A) B                  ->    30 (A) B
                -0.5456                         -0.0102
   -0.0222       12 (A) A                  ->    30 (A) A
                -0.5456                         -0.0102
   -0.0130       11 (A) A      11 (A) B    ->    85 (A) A      85 (A) B
                -0.7004       -0.7004            0.4760        0.4760
    0.0130       11 (A) A      11 (A) B    ->    85 (A) B      85 (A) A
    0.0130       11 (A) B      11 (A) A    ->    85 (A) A      85 (A) B
   -0.0130       11 (A) B      11 (A) A    ->    85 (A) B      85 (A) A
   Computing CCSD intermediates for later calculations in double precision
   Finished.
   CCSD calculation:   CPU 4088.45 s  wall 167.01 s
   EOMEE-CCSD calculation:   CPU 6.75 s  wall 0.65 s
          Solving for EOMEA-CCSD/MP2 A transitions.
        EOMEA-CCSD/MP2 right amplitudes will be solved using Davidson.
          Amplitudes will be solved using standard  algorithm.
       Hard-coded thresholds:
       LinDepThresh=1.00e-15  NormThresh=1.00e-06  ReorthogonThresh=1.00e-02
        Roots     MaxVec    MaxIter   Precond   Conv      Shift
        1         120       60        1         1.00e-06  0.00e+00
        Iter ConvRoots NVecs ResNorm Current eigenvalues (eV)
        0    0      1     4.04e-02   -4.8377
        1    0      2     5.60e-02   -5.1245
        2    0      3     9.38e-04   -5.4389
        3    0      4     6.26e-05   -5.4521
        4    0      5     6.61e-06   -5.4529
        5    0      6     1.93e-06   -5.4531
        6    1      7     1.53e-07   -5.4531*
       Davidson procedure converged
   EOMEA transition 1/A
   Total energy = -151.77384926 a.u.  Excitation energy = -5.4531 eV.
   R1^2 = 0.9832  R2^2 = 0.0168  Res^2 = 1.53e-07
   Conv-d = yes
   Amplitude    Transitions between orbitals
   -0.9868       infty       ->    14 (A) B
   -0.0600       infty       ->    17 (A) B
   -0.0472       infty       ->    20 (A) B
   -0.0392       infty       ->    29 (A) B
                Summary of significant orbitals:
                 Number  Type             Irrep      Energy
                 14      Vir  Beta       14 (A)     -0.1826
                 17      Vir  Beta       17 (A)     -0.1006
                 20      Vir  Beta       20 (A)     -0.0700
                 29      Vir  Beta       29 (A)     -0.0107
   EEs and amplitudes of EOMEA can not be exported to fchk file
        EOMEA-CCSD/MP2 left amplitudes will be solved using Davidson.
          Amplitudes will be solved using MOM  algorithm.
        0    0      1     1.24e-03   -5.4531
        1    0      2     1.09e-03   -5.4531
        2    0      3     2.04e-05   -5.4531
        3    0      4     2.09e-06   -5.4531
        4    1      5     1.92e-07   -5.4531*
             EOM amplitude response will be solved using DIIS.
             Start     Size      MaxIter   EConv     ZConv
             3         7         100       1.00e-06  1.00e-06
              Enorm      Zdiff       Comment
       1     6.65e-02   4.16e-02
       2     2.22e-02   1.41e-02
       3     1.05e-02   4.80e-03
       4     3.23e-03   3.30e-03     Switched to DIIS steps.
Any suggestion would be helpful.
Yuiki
Responding to this and your previous, related question (Negative frequency): faced with a pesky imaginary frequency, I’m not sure that a larger basis set would have been my first idea to try to sidestep the problem, especially when 6-31G* can be used instead. See my post on the other question - I think your imaginary frequency may be a RHF/UHF issue.
We used mem_total = ~60% of available memory (40GB) and the job have been running for one day without any crash. What is the available memory on your machine? BTW, you have to set mem_static = 2000; otherwise, the default is 192 MB.
Thank you very much for examining my calculation. I am now running on university’s cluster with 32 cores, and can request 48GB per core at most, thus in total, 1536 GB should be available though I am not sure Qchem can fully take advantage of that size of memory.
Thank you for pointing out to set MEM_STATIC = 2000. I just thought 2GB may be too much for fortran code but it seems not.
Because it stucks at the integral transformation stage even when I allocated 2GB for MEM_STATIC, this is probably already at the maximum speed?
The coupled cluster code should be using MEM_TOTAL not MEM_STATIC, so you should set the former equal to the total memory available on your hardware. (There are only a few things left in Q-Chem that require large MEM_STATIC and they are gradually being eliminated).
